FS: 1974 2.0 LE, Former LE (Bumble Bee) for sale |
codices |
Jun 17 2019, 04:17 PM
Member Group: Members Posts: 95 Joined: 9-October 08 From: Morrison, Colorado Member No.: 9,626 Region Association: Rocky Mountains |
For sale $15,000 (cash or wire transfer) Bumble Bee repainted Guards red 18 years ago with a body restoration. All LE items in place with a refurbished interior. Extra oil pressure and cylinder head gauges installed. Shumacher trickle charger installed. Remote rear trunk with "Porsche " reflector and twin struts. Special thin fiberglass rear spoiler installed with new paint and body work. Electric windshield washer installed. Rubber/fiberglass front air dam, 180 # progressive rear springs, Kuhmo Ecsta 195/55- 15 tires on original LE Mahle wheels. Paint marred on passenger rear side (photo included) along with battery tray needs replacement (all intact but center bottom--covered by aluminum plate (photo included).
Engine and transaxle original numbers along with European flat top pistons. 2.0 heads with .030 "plunge cut" for increased compression. Dell Orto 40 DRLA carbs with CB performance bar linkage. Web Cam performance hydraulic cam with lifters and performance springs to match. Melling oil pump, engine assembly has a static and dynamic balance of all moving parts. Crane/Allison optical/electrical ignition in a .050 distributor. Light weight reduction gear starter, stock heat exchangers with Monza four pipe exhaust. Extra oil (Joe Gibbs DT-50). 38 extra parts (refurbished engine case, extra side shifter tranny, etc). I have all this listed on a separate sheet. Attached thumbnail(s) |
mao_junior |
Jun 19 2019, 11:28 PM
I'm new here ... Group: Members Posts: 0 Joined: 15-November 13 From: Brooklyn, NY Member No.: 16,650 Region Association: North East States |
sent PM (IMG:style_emoticons/default/smile.gif)
codices |
Jun 20 2019, 04:17 PM
Called you at 4:16 pm my time. Voicemail not set up at your end. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:04 PM |
