Looking for GoldWing airbox on dellorto photos, Anyone with experience on dellorto/GoldWing airbox |
MarkV |
Jun 18 2019, 02:21 PM
I was going to do it and bought a set on ebay. Never pulled the trigger because they are huge and I don't want to lose my rain tray. They also won't work with my throttle linkage.
http://www.914world.com/bbs2/index.php?sho...=194570&hl= |
wes |
Jun 18 2019, 02:24 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
Try again! I’ve got a set of GoldWing airbox’s to quite my Dellorto’s down a bit and found an older thread on it hear. My problem is that the linkage on my setup is backwards to the photo in the thread I was going by as my linkage is in front and higher and in the way, first photo is mine.
next photo from previous thread Any advice and or photos would be great. I might add I don’t mess with carbs and to my knowledge the Dellorto’s are perfectly adjusted not by me. |
thelogo |
Jun 18 2019, 09:09 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Try again! I’ve got a set of GoldWing airbox’s to quite my Dellorto’s down a bit and found an older thread on it hear. My problem is that the linkage on my setup is backwards to the photo in the thread I was going by as my linkage is in front and higher and in the way, first photo is mine. next photo from previous thread Any advice and or photos would be great. I might add I don’t mess with carbs and to my knowledge the Dellorto’s are perfectly adjusted not by me. Lose the rain train If you want the intake silencers (IMG:style_emoticons/default/smoke.gif) |
wes |
Jun 18 2019, 09:35 PM
Try again! I’ve got a set of GoldWing airbox’s to quite my Dellorto’s down a bit and found an older thread on it hear. My problem is that the linkage on my setup is backwards to the photo in the thread I was going by as my linkage is in front and higher and in the way, first photo is mine. next photo from previous thread Any advice and or photos would be great. I might add I don’t mess with carbs and to my knowledge the Dellorto’s are perfectly adjusted not by me. Lose the rain train If you want the intake silencers (IMG:style_emoticons/default/smoke.gif) Have no idea what you’re referring to “rain train”. |
rhodyguy |
Jun 19 2019, 09:23 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
I think 'tray'. (IMG:style_emoticons/default/confused24.gif) The one under the lid. That style of throttle cable holder limits the direction of carb installation.
7TPorsh |
Jun 19 2019, 10:07 AM
Hi Wes, here's my original thread: GoldWing
wes |
Jun 19 2019, 11:19 AM
Rain tray, Auto spell check! I haven’t used a rain tray since early 80’s on my first 914. I have a GT lid no rain tray, it’s a little fat Preformance stroker and precautions have been addressed for heating when driving hard in the mountains near our home. So between the stroker sucking through the Dellorto’s the GT lid and a plastic rear window with the top off plus most likely my old abused ears, i looked at means to make her sing with a little less volume. Even though I love the sound driving a little hard on a warmer day for any length of time gets a bit old.
So as to putting this together I’ve found I can flip the air cleaner base plate and replace the crossbar in the rear rather than the front setting the crossbar lower allowing room for the new airbox. On the way! |
wes |
Jun 19 2019, 11:36 AM
Hi Gary, you’re article was what got me looking at this sound volume solution so when oddly enough the airbox soddenly were available I jumped on it, thanks
ValcoOscar |
Jun 20 2019, 09:54 AM
Garage Life Group: Members Posts: 2,382 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
I like this Airbox set up (for my weber 44's) but a bit much $$$ for me.
Maybe they can work with Dellorto carbs??? http://kaefer.motor-sport-service.de/html/...ranlagen_5.html Oscar |
wes |
Jun 21 2019, 07:11 PM
Well it’s done and the volume is much better besides the fact it’s a deeper better sound.
Rather than setting up the linkage in the rear as I was going to do I flipped the filter baseplate over allowing room for the airbox but first had to cut away a small section too clear the carb circled in red in the first photo. Next cut the threaded linkage rod for each carb and adjust them. The one airbox was just rubbing on the engine lid a bit so ground the frame a little to clear and done. Much better sound! |
wes |
Jun 21 2019, 07:15 PM
Lo-Fi Version | Time is now: 6th May 2024 - 10:10 AM |
