Correct Airbox for a 914-6 on the Samba |
Mike Fitton |
Jun 20 2019, 08:48 AM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
This is the correct plastic airbox for a 914-6, price negotiable with this seller. You will have to source the correct plastic snorkel which points opposite the 911 one.
https://www.thesamba.com/vw/classifieds/det....php?id=1473294 |
rgalla9146 |
Jun 20 2019, 05:57 PM
Mike...I beg to differ.
If someone needs an air filter housing that will probably work on a 6 this might do. It is correctly described by the seller as a 911 part. The plastic studs, plastic wing nuts and plastic vent tubes tell me this is for a MFI 911 probably '72-'73 It is not correct for a 914 6 If someone need photos for their search I will gladly post Rory |
Mike Fitton |
Jun 21 2019, 07:30 AM
Here you go, all the info you need to decide:
http://mail.914world.com/bbs2/index.php?showtopic=213849 |
gereed75 |
Jun 21 2019, 08:35 AM
Senior Member Group: Members Posts: 1,241 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Throwing in my two cents. Hate to disagree with two esteemed members, but at least early six’s had the provisions for the extra cold start injection lines and metal connection for the vent lines.
I suspect that there were variations on these over the two+ years that they were installed. I think everyone can agree, they were plastic and the snorkel pointed towards the distributor and the snorkel was smooth. As to the consistency of which wing nuts and vent connection (plastic or steel) and whether smooth (no cold start injector tubes) or not, I am not so sure. It is possible I quess that later cars got the no cold start injector, plastic vent fitting and nuts 911 boxes. What about the holes between the inlet ports. My understanding is these are there on the six boxes to accommodate the carb vents, and not there on the 911 MFI boxes. I suppose this too could be inconsistent and therefore inconclusive, and they could be easily added to a 911 MFI box. |
skier2.0 |
Jun 22 2019, 09:54 AM
Newbie Group: Members Posts: 34 Joined: 30-May 14 From: United States Member No.: 17,422 Region Association: MidAtlantic Region |
Throwing in my two cents. Hate to disagree with two esteemed members, but at least early six’s had the provisions for the extra cold start injection lines and metal connection for the vent lines. I suspect that there were variations on these over the two+ years that they were installed. I think everyone can agree, they were plastic and the snorkel pointed towards the distributor and the snorkel was smooth. As to the consistency of which wing nuts and vent connection (plastic or steel) and whether smooth (no cold start injector tubes) or not, I am not so sure. It is possible I quess that later cars got the no cold start injector, plastic vent fitting and nuts 911 boxes. What about the holes between the inlet ports. My understanding is these are there on the six boxes to accommodate the carb vents, and not there on the 911 MFI boxes. I suppose this too could be inconsistent and therefore inconclusive, and they could be easily added to a 911 MFI box. I believe they sit lower than the 911 covers so they don't interfer with the engine cover. Also they have clips and holes on the sides for the cold start injection tubes. These tube had a recall due to fires. |
gereed75 |
Jun 22 2019, 12:43 PM
Nope don’t sit lower. Box and mounts are identical to 911.
Mike Fitton |
Jun 22 2019, 07:26 PM
I thought the indent on the underside made it a 194-6 Box.
914Sixer |
Jun 22 2019, 08:58 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Here you go to add to the confusion This one has a bottom drain and a metal plug.
rgalla9146 |
Jun 23 2019, 06:01 AM
Here you go to add to the confusion This one has a bottom drain and a metal plug. Now we're talkin' Attached thumbnail(s) |
rgalla9146 |
Jun 23 2019, 06:02 AM
another
gereed75 |
Jun 23 2019, 11:56 AM
I have both a known 911 and a known correct six at home. Won’t be there till Tuesday. Will check for the indent then and take a few pix. Pretty sure both have the indent. I am Certain early sixes had the injector line holes, metal vent T connection and metal snorkel studs.
johnhora |
Jun 23 2019, 01:35 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Mike Fitton |
Jun 23 2019, 05:16 PM
rgalla9146 |
Jun 23 2019, 06:19 PM
db9146 |
Jun 23 2019, 09:52 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I beg to differ......MFI pump on a 914-6 is on the passenger side.
johnhora |
Jun 23 2019, 09:53 PM
Yes in.911 engine fan faces rear so dent is on driver side
rgalla9146 |
Jun 24 2019, 04:53 AM
I beg to differ......MFI pump on a 914-6 is on the passenger side. OK, No matter what chassis it's in, any engine with MFI has the pump over the 1-2-3 cylinder bank. The bump on the air filter housing pictured is over the 4-5-6 bank. I don't know why. I do know it is not for a 914 6 Maybe for the 914 6 Turbo ? |
johnhora |
Jun 24 2019, 03:30 PM
OK I think I see what you are talking about now...
Correct:the MFI pump is on the 123 bank. you are referring to the somewhat similar dent on the 456 under side next to the plastic hose connector. That is the side and area for the oil cooler "tunnel" in the fan shroud. Maybe the dent was there for extra clearance with the 2.2S , 2.4 MFI or 2.7 Check out the fan shrouds in this picture....the 2.2 and 2.4 seem to have a larger "tunnel" http://www.early911sregistry.org/forums/sh...code-fan-shroud What you think? |
rgalla9146 |
Jun 24 2019, 08:03 PM
The bottoms of the air filters of the two Sixes I currently own.
There were four others along the way. No bump to accommodate anything. Attached thumbnail(s) |
rgalla9146 |
Jun 24 2019, 08:15 PM
The additional duct to the oil cooler as seen on all 914 6s
This engine has all stock equipment with the exception of the K&N rainshields and my pop bottle puke tank. Please note the S registry 'color chart' does not list the additional duct on a 2.0 engine. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 28th April 2024 - 06:55 AM |
