Found this kit on AliExpress, anyone using one of these kits ? |
porschetub |
Jun 22 2019, 03:32 PM
Look well made and specific to T4 engines,$46USD with free shipping..could you really go wrong (IMG:style_emoticons/default/confused24.gif) .
The description has no details on the type of manifold fitment so I presume it works with the tall ones as they are common. I think they look similar to the system that came on the Brazil built 1600 twin Solex carb busses we used to get years ago in my country,I designed a system off this setup and used it on my offroader with Weber ICT's to good result,once setup I never adjusted it again. The Brazilian linkage was poorly made with very small diameter pivot joints that wore out fast, the pivot crank suffered the same wear issues also. This kit appears to be an improvement on the above. |
porschetub |
Jun 22 2019, 05:36 PM
Look well made and specific to T4 engines,$46USD with free shipping..could you really go wrong (IMG:style_emoticons/default/confused24.gif) . The description has no details on the type of manifold fitment so I presume it works with the tall ones as they are common. I think they look similar to the system that came on the Brazil built 1600 twin Solex carb busses we used to get years ago in my country,I designed a system off this setup and used it on my offroader with Weber ICT's to good result,once setup I never adjusted it again. The Brazilian linkage was poorly made with very small diameter pivot joints that wore out fast, the pivot crank suffered the same wear issues also. This kit appears to be an improvement on the above. Sorry please move to garage,thanks. |
914Sixer |
Jun 22 2019, 09:01 PM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
We called those kits monkey motion ones. Beyond bad. That's why everybody went to hex bar.
euro911 |
Jun 24 2019, 12:38 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,848 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
The bell crank throttle linkage kit made by CSP works great
IronHillRestorations |
Jun 24 2019, 07:51 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I think a side by side comparison between CSP and the Brazilian will reveal a definitive difference between the two. For roughly $80 more I'll opt for the CSP, the quality is impressive.
The little spring clips for the ball studs looks very hokey to me, especially since those linkage ends aren't super pricey. Imagine trying to put those things on a 914 linkage. |
Lo-Fi Version | Time is now: 6th May 2024 - 03:19 AM |
