ALWAYS use Jack stands |
drem914 |
Nov 29 2019, 06:31 PM
Senior Member Group: Members Posts: 1,030 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
You can never be too careful when you are about to crawl under a car. Even though the 914 is only 2,000 pounds....I can't lift it if it falls on me. I have a scissor lift and even when using it I always rest it on the steel locks and never leave it on the hydraulics. (IMG:style_emoticons/default/beerchug.gif) Would this be the same for a QuickJack since it already has positive locks at two different mounting heights off of the hydraulics? Or should you add jack stands as a secondary back up? |
Beach914 |
Nov 29 2019, 06:39 PM
Senior Member Group: Members Posts: 966 Joined: 28-March 10 From: Aliso Viejo Member No.: 11,519 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) But let me go a step further Have a back up to the jack stands. Leave a jack in place - just in case. Or, leave a tire underneath. Something else to buy an extra factor of safety. Sometimes I’ll double up jack stands (IMG:style_emoticons/default/agree.gif) I’m a scaredy-cat. I always shove something extra under the car. A couple spare tires or similar. Me too. Big time wuss. Not a way that I want to go. |
Nov 29 2019, 06:44 PM
You can never be too careful when you are about to crawl under a car. Even though the 914 is only 2,000 pounds....I can't lift it if it falls on me. I have a scissor lift and even when using it I always rest it on the steel locks and never leave it on the hydraulics. (IMG:style_emoticons/default/beerchug.gif) Would this be the same for a QuickJack since it already has positive locks at two different mounting heights off of the hydraulics? Or should you add jack stands as a secondary back up? It never hurts to be extra cautious. I always have something extra under the car when I’m under. If you use a lift, you always want to lift a couple inches and bounce both ends to make sure it’s not going to slide off. Also be aware of weight shift when you drop an engine. |
ClayPerrine |
Nov 29 2019, 07:05 PM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Even with a lift set on the safety locks I put a pole jack under the transmission. It may not save the car, but hopefully I will get extra time to get clear if the lift fails. Somebody needs to let Gint know about this thread. He has intimate knowledge and experience with this subject. |
brcacti |
Nov 29 2019, 07:29 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
I put mine up on the newer plastic type ramps, is this considered very safe?
Coondog |
Nov 29 2019, 07:48 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
I have a Quickjack but also stick these under the tires. There used to level RVs
Larmo63 |
Nov 29 2019, 08:24 PM
Wheel chocks and Esco jack stands.
I trust my life with these things, they better be great quality. |
michael7810 |
Nov 29 2019, 08:32 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
I always use jack stands except the other day I forgot and climbed under a car at work and it suddenly dropped about 2” while I was under it. The floor jack must be starting to fail. Took about 15 minutes for my heart rate to settle down before I could get back under it with jack stands installed. I was lucky.
Coondog |
Nov 29 2019, 08:52 PM
Check out race ramps.
raceramps.com |
bkrantz |
Nov 29 2019, 09:04 PM
914 Guru Group: Members Posts: 7,766 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
And not just 1 jack stand, or any type.
Besides good jack stands, I always put the removed tire/wheel(s) under the car as a back up. |
drem914 |
Nov 29 2019, 10:00 PM
You can never be too careful when you are about to crawl under a car. Even though the 914 is only 2,000 pounds....I can't lift it if it falls on me. I have a scissor lift and even when using it I always rest it on the steel locks and never leave it on the hydraulics. (IMG:style_emoticons/default/beerchug.gif) Would this be the same for a QuickJack since it already has positive locks at two different mounting heights off of the hydraulics? Or should you add jack stands as a secondary back up? It never hurts to be extra cautious. I always have something extra under the car when I’m under. If you use a lift, you always want to lift a couple inches and bounce both ends to make sure it’s not going to slide off. Also be aware of weight shift when you drop an engine. Nothing like that. Just for general maintenance and cleaning. |
RickS |
Nov 29 2019, 11:06 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
For oil changes and clutch cable adjustments and other small stuff I use ramps. Have pin jackstands when the wheels come off and always chock the tires. Got some great chocks at Harbor Freight. Also when the wheel/s are off, they go under the car for extra insurance. Life as you know it can change in a blink of an eye, don’t force the blink.
bdstone914 |
Nov 29 2019, 11:09 PM
Should also add - no cinder blocks - EVER! In case I wasn’t clear - cinder blocks are not a substitute for jack stands Keep yourself safe (IMG:style_emoticons/default/agree.gif) Or milk crates |
iankarr |
Nov 29 2019, 11:18 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Would this be the same for a QuickJack since it already has positive locks at two different mounting heights off of the hydraulics? Or should you add jack stands as a secondary back up? I have a QuickJack and qlways use stands as a backup. Worth it for the peace of mind and extra margin of safety. |
RickS |
Nov 30 2019, 12:41 AM
barefoot |
Nov 30 2019, 08:01 AM
Senior Member Group: Members Posts: 1,274 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Should also add - no cinder blocks - EVER! In case I wasn’t clear - cinder blocks are not a substitute for jack stands Keep yourself safe Disagree, I use them regularly but always have 2x12 on top so tires rest on solid wood. When placed under tires, always have car in gear, emergency brake on and chicks. I'm still alive ! Barefoot |
Lo-Fi Version | Time is now: 17th May 2024 - 06:51 PM |
