Test cold start valve, tips to testing CSV before I replace it |
Fatboy007 |
Jun 24 2019, 08:02 PM
Member Group: Members Posts: 62 Joined: 23-May 17 From: San Diego, ca. Member No.: 21,124 Region Association: Southern California |
Looking for tips on how to test the CSV before I spend $$ to replace it how do i know it's bad...And best way to get those two Flat-Head screws outta there if I have to replace it. Thank you (IMG:style_emoticons/default/biggrin.gif)
ndfrigi |
Jun 24 2019, 08:16 PM
Advanced Member Group: Members Posts: 2,928 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
direct 12 volts. maybe attach a rubber hose on one end to blow air to test the flow. After applying 12 volts, the element inside should get warm/heat and makes the valve close. when cold and blow air on one side, you should feel the air from the other side. offcourse when valve close, you can feel lesser air (i think not totally close but u will notice less air)
jim_hoyland |
Jun 24 2019, 08:29 PM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
direct 12 volts. maybe attach a rubber hose on one end to blow air to test the flow. After applying 12 volts, the element inside should get warm/heat and makes the valve close. when cold and blow air on one side, you should feel the air from the other side. offcourse when valve close, you can feel lesser air (i think not totally close but u will notice less air) Ah...this tests the AAR, not the CSV. |
ChrisFoley |
Jun 24 2019, 08:40 PM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
You don't need a cold start valve in San Diego. If you aren't sure it works right, remove the hose and plug it. Disconnect the wiring. Continue driving.
ndfrigi |
Jun 25 2019, 10:49 AM
direct 12 volts. maybe attach a rubber hose on one end to blow air to test the flow. After applying 12 volts, the element inside should get warm/heat and makes the valve close. when cold and blow air on one side, you should feel the air from the other side. offcourse when valve close, you can feel lesser air (i think not totally close but u will notice less air) Ah...this tests the AAR, not the CSV. ooops yup ur correct Jim. Sorry Stacey! when I read ur thread, it just went to my mind about CSV and not AAR. My bad! huhuhu |
Fatboy007 |
Jun 26 2019, 08:56 PM
Thank you to all... Chris, took your advise, by-passed the CSV and plugged it up... runs great. Thank you . (IMG:style_emoticons/default/piratenanner.gif)
Lo-Fi Version | Time is now: 18th May 2024 - 10:49 PM |
