Turn Signal Wiring Harness pigtail |
RangerDick |
Jun 28 2019, 08:57 AM
Newbie Group: Members Posts: 18 Joined: 15-May 17 From: Burlingame, CA Member No.: 21,104 Region Association: Northern California |
Looking for the the connector block and pigtail harness for a 1973 2.0 liter Turn Signal. This is the female side of the connector block which plugs into the Turn Signal as it exits under the steering column. Need block and about 6 inches of wiring. Thanks in advance.
Matt |
914werke |
Jun 28 2019, 09:42 AM
"I got blisters on me fingers" Group: Members Posts: 10,106 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I have a bunch of that stuff, check HERE (IMG:style_emoticons/default/smile.gif)
If you dont see it, doesn't mean I dont have it. |
RangerDick |
Jun 28 2019, 10:35 AM
PM Sent. didn't see it on the site, but You show it on the link.
Thanks. |
jcd914 |
Jun 28 2019, 06:23 PM
If you are looking for the connector and harness that plug into the turn signal switch, it is part of the main wiring harness and will have to be cut off a harness. The connector block/housing can be removed the wires have to be cut off.
I have a harness that has already been cut up and I still have that section. I won't be back in town until Monday evening, so I can get to it to send a picture. So if 914werk does not have what you need and you are interest let me know. Thanks Jim |
Lo-Fi Version | Time is now: 29th May 2024 - 09:14 PM |
