RangerDick
Jun 28 2019, 08:57 AM
Looking for the the connector block and pigtail harness for a 1973 2.0 liter Turn Signal. This is the female side of the connector block which plugs into the Turn Signal as it exits under the steering column. Need block and about 6 inches of wiring. Thanks in advance.
Matt
914werke
Jun 28 2019, 09:42 AM
I have a bunch of that stuff, check
HERE If you dont see it, doesn't mean I dont have it.
RangerDick
Jun 28 2019, 10:35 AM
PM Sent. didn't see it on the site, but You show it on the link.
Thanks.
jcd914
Jun 28 2019, 06:23 PM
If you are looking for the connector and harness that plug into the turn signal switch, it is part of the main wiring harness and will have to be cut off a harness. The connector block/housing can be removed the wires have to be cut off.
I have a harness that has already been cut up and I still have that section.
I won't be back in town until Monday evening, so I can get to it to send a picture.
So if 914werk does not have what you need and you are interest let me know.
Thanks
Jim
