Another oil cooling discussion, Front cooling |
RolinkHaus |
Jun 30 2019, 06:15 AM
Member Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
Just curious if this system is sufficient for cooling. Planning to mount this system to the front with hard aluminum lines to the rear. Will this do the job? I have a 76 fuel injected 2.0.
RolinkHaus |
Jun 30 2019, 08:48 AM
Got it, that's what I was wondering. Temp gauge running a little hot after driving for 30 minutes.
Racer |
Jul 17 2019, 06:30 AM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
Got it, that's what I was wondering. Temp gauge running a little hot after driving for 30 minutes. hotter than usual? hotter cause it was 100 degrees outside? Agree with others that the drama of a front mount might not be needed without learning more first. A good gauge with numbers is a good first step to learn what temps you are actually dealing with. |
Lo-Fi Version | Time is now: 19th May 2024 - 08:11 PM |
