Trailing Arm Bolts, Who sells these ? What is size ? |
jim_hoyland |
Jul 10 2019, 12:14 PM
Get that VIN ? Group: Members Posts: 9,303 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
What is the metric size of the trailing Arm bolts, the ones that hold the shims
Who sell these ? Attached image(s) |
Jul 10 2019, 12:18 PM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
2 Hexagon-head bolt
M 10 X 55 - 6 - 900 074 192 01 Any fastener place should have them. Use a site like this - https://nemigaparts.com/cat_spares/pet/porsche/914/570u/ to look up parts. It's setup very easy to find even the small nuts and bolts. |
914fahrer |
Jul 10 2019, 01:06 PM
Member Group: Members Posts: 103 Joined: 12-November 14 From: Berlin/Germany Member No.: 18,115 Region Association: Germany |
The size M10x55 is correct but the they have a higher grade 10.9 are the right bolt´s
dr914@autoatlanta.com |
Jul 10 2019, 01:41 PM
914 Guru Group: Members Posts: 7,868 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I agree, have to be a higher grade since they are for the suspension, also sometimes when getting rid of neg camber without replacing springs, some use longer bolts to compensate for the excessive number of shims!!!!!!!! (not a good idea)
The size M10x55 is correct but the they have a higher grade 10.9 are the right bolt´s |
Ed_Turbo |
Member Group: Members Posts: 440 Joined: 5-June 17 From: Hacienda Heights, Ca. Member No.: 21,151 Region Association: Southern California |
2 Hexagon-head bolt M 10 X 55 - 6 - 900 074 192 01 Any fastener place should have them. Use a site like this - https://nemigaparts.com/cat_spares/pet/porsche/914/570u/ to look up parts. It's setup very easy to find even the small nuts and bolts. Nice link dude, I am saving this for the Jedi Archives. Grab a screw chart plate online or at the hardware store, they are very handy for any job. Some guys here plate them if you are going straight to Pebble Beach. -The real Eddie |
Jul 10 2019, 02:01 PM
2 Hexagon-head bolt M 10 X 55 - 6 - 900 074 192 01 Any fastener place should have them. Use a site like this - https://nemigaparts.com/cat_spares/pet/porsche/914/570u/ to look up parts. It's setup very easy to find even the small nuts and bolts. Nice link dude, I am saving this for the Jedi Archives. Grab a screw chart plate online or at the hardware store, they are very handy for any job. Some guys here plate them if you are going straight to Pebble Beach. -The real Eddie (IMG:style_emoticons/default/smile.gif) Attached image(s) |
John |
Jul 10 2019, 02:35 PM
I use very long bolts and double nut them on the top of the console. This accomplishes two things. (1) They never get loose, (2) This keeps junk and debris from entering the open tube where the short bolts seat and prevents rust (my plastic caps were long gone 20 years ago).
I am using grade 12.9 socket head cap screws from McMaster Carr. |
jim_hoyland |
Jul 10 2019, 03:49 PM
Thanks for that info; I assume the pitch is 1.5 ?
Larmo63 |
Jul 10 2019, 06:47 PM
Jim, Bruce Stone should have this stuff in bulk and he may even have them plated up all pretty.
Jul 10 2019, 07:29 PM
As Ed turbo said - get a screw chart. They are $1 at the hardware store and very useful.
Maltese Falcon |
Jul 10 2019, 07:32 PM
Advanced Member Group: Members Posts: 4,662 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Always good to run a tap up in the threaded area, clear out the debri that will usually work its way down into the new bolt you are installing...
914 Ranch |
Jul 10 2019, 08:07 PM
Team Sharp where the 914 grow wings Group: Members Posts: 1,411 Joined: 29-January 16 From: TheNorth Shore Retreat. Deland Member No.: 19,611 Region Association: South East States |
Jim, Hillco Fasteners has everything you will ever need. In Garden Grove near Brookhurst and Sanford.
jim_hoyland |
Jul 10 2019, 08:09 PM
jim_hoyland |
Jul 10 2019, 08:11 PM
Jim, Hillco Fasteners has everything you will ever need. In Garden Grove near Brookhurst and Sanford. Thanks Joe, that is a great store, will hit it.... (IMG:style_emoticons/default/smile.gif) |
914werke |
Jul 10 2019, 09:41 PM
"I got blisters on me fingers" Group: Members Posts: 10,083 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Always good to run a tap up in the threaded area, clear out the debri that will usually work its way down into the new bolt you are installing... there were OE plastic plugs that should have been in the top of those holes to prevent this. |
Maltese Falcon |
Jul 10 2019, 11:05 PM
Always good to run a tap up in the threaded area, clear out the debri that will usually work its way down into the new bolt you are installing... there were OE plastic plugs that should have been in the top of those holes to prevent this. Still have these OE caps ( cap-plug-like) things in place on our 3 914s ; still had 40 years worth of fine dirt in the threads. When I started to ruin one of the threads during an R+R...I decided to use the tap method. |
banananose914 |
Jul 10 2019, 11:20 PM
Member Group: Members Posts: 235 Joined: 20-November 13 From: california Member No.: 16,681 Region Association: None |
What is the metric size of the trailing Arm bolts, the ones that hold the shims Who sell these ? Hey Jim. We”re going to work on Cairo”s car on Sunday. Leave me a number via a PM and I’ll hook you up with some plated, original bolts. Bring the one you have to match them up. Jim |
jim_hoyland |
Jul 11 2019, 05:30 AM
What is the metric size of the trailing Arm bolts, the ones that hold the shims Who sell these ? Hey Jim. We”re going to work on Cairo”s car on Sunday. Leave me a number via a PM and I’ll hook you up with some plated, original bolts. Bring the one you have to match them up. Jim Thanks (IMG:style_emoticons/default/smile.gif) But I can't change them out at this time.It's going to be a project this fall... |
Jul 11 2019, 05:50 AM
What is the metric size of the trailing Arm bolts, the ones that hold the shims Who sell these ? Hey Jim. We”re going to work on Cairo”s car on Sunday. Leave me a number via a PM and I’ll hook you up with some plated, original bolts. Bring the one you have to match them up. Jim Thanks (IMG:style_emoticons/default/smile.gif) But I'm not going to change them out at this time. They are less than a dollar through the big suppliers and available all the time. |
jim_hoyland |
Jul 11 2019, 07:00 AM
QUOTE Still have these OE caps ( cap-plug-like) things in place on our 3 914s ; still had 40 years worth of fine dirt in the threads. When I started to ruin one of the threads during an R+R...I decided to use the tap method. I want to source these too; any sources ? |
Lo-Fi Version | Time is now: 21st May 2024 - 06:23 PM |
