jim_hoyland
Jul 10 2019, 12:14 PM
What is the metric size of the trailing Arm bolts, the ones that hold the shims
Who sell these ?
Jul 10 2019, 12:18 PM
2 Hexagon-head bolt
M 10 X 55 - 6 - 900 074 192 01
Any fastener place should have them.
Use a site like this -
https://nemigaparts.com/cat_spares/pet/porsche/914/570u/to look up parts. It's setup very easy to find even the small nuts and bolts.
914fahrer
Jul 10 2019, 01:06 PM
The size M10x55 is correct but the they have a higher grade 10.9 are the right bolt´s
dr914@autoatlanta.com
Jul 10 2019, 01:41 PM
I agree, have to be a higher grade since they are for the suspension, also sometimes when getting rid of neg camber without replacing springs, some use longer bolts to compensate for the excessive number of shims!!!!!!!! (not a good idea)
QUOTE(914fahrer @ Jul 10 2019, 12:06 PM)
Ed_Turbo
QUOTE(mepstein @ Jul 10 2019, 11:18 AM)
2 Hexagon-head bolt
Nice link dude, I am saving this for the Jedi Archives.
Grab a screw chart plate online or at the hardware store, they are very handy for any job.
Some guys here plate them if you are going straight to Pebble Beach.
-The real Eddie
Jul 10 2019, 02:01 PM
QUOTE(Ed_Turbo @ Jul 10 2019, 03:41 PM)
2 Hexagon-head bolt
-The real Eddie
John
Jul 10 2019, 02:35 PM
I use very long bolts and double nut them on the top of the console. This accomplishes two things. (1) They never get loose, (2) This keeps junk and debris from entering the open tube where the short bolts seat and prevents rust (my plastic caps were long gone 20 years ago).
I am using grade 12.9 socket head cap screws from McMaster Carr.
jim_hoyland
Jul 10 2019, 03:49 PM
Thanks for that info; I assume the pitch is 1.5 ?
Larmo63
Jul 10 2019, 06:47 PM
Jim, Bruce Stone should have this stuff in bulk and he may even have them plated up all pretty.
Jul 10 2019, 07:29 PM
As Ed turbo said - get a screw chart. They are $1 at the hardware store and very useful.
Maltese Falcon
Jul 10 2019, 07:32 PM
Always good to run a tap up in the threaded area, clear out the debri that will usually work its way down into the new bolt you are installing...
914 Ranch
Jul 10 2019, 08:07 PM
Jim, Hillco Fasteners has everything you will ever need. In Garden Grove near Brookhurst and Sanford.
jim_hoyland
Jul 10 2019, 08:09 PM
QUOTE(Maltese Falcon @ Jul 10 2019, 06:32 PM)
Yes !
jim_hoyland
Jul 10 2019, 08:11 PM
QUOTE(914 Ranch @ Jul 10 2019, 07:07 PM)
Thanks Joe, that is a great store, will hit it....
914werke
Jul 10 2019, 09:41 PM
QUOTE(jim_hoyland @ Jul 10 2019, 07:09 PM)
Yes !
there were OE plastic plugs that should have been in the top of those holes to prevent this.
Maltese Falcon
Jul 10 2019, 11:05 PM
QUOTE(914werke @ Jul 10 2019, 08:41 PM)
Yes !
Still have these OE caps ( cap-plug-like) things in place on our 3 914s ; still had 40 years worth of fine dirt in the threads. When I started to ruin one of the threads during an R+R...I decided to use the tap method.
banananose914
Jul 10 2019, 11:20 PM
QUOTE(jim_hoyland @ Jul 10 2019, 11:14 AM)
Who sell these ?
Hey Jim. We”re going to work on Cairo”s car on Sunday. Leave me a number via a PM and I’ll hook you up with some plated, original bolts. Bring the one you have to match them up. Jim
jim_hoyland
Jul 11 2019, 05:30 AM
QUOTE(banananose914 @ Jul 10 2019, 10:20 PM)
Who sell these ?
Thanks
But I can't change them out at this time.It's going to be a project this fall...
Jul 11 2019, 05:50 AM
QUOTE(jim_hoyland @ Jul 11 2019, 07:30 AM)
Who sell these ?
Thanks
But I'm not going to change them out at this time.
They are less than a dollar through the big suppliers and available all the time.
jim_hoyland
Jul 11 2019, 07:00 AM
I want to source these too; any sources ?
Jul 11 2019, 07:18 AM
QUOTE(jim_hoyland @ Jul 11 2019, 09:00 AM)
You can take a used bolt, grind a slot down the side and make a thread chaser.
