Aftermarket Rims and Tire Size |
JohnS |
Jul 11 2019, 07:46 PM
Newbie Group: Members Posts: 3 Joined: 23-June 19 From: Maricopa, Arizona Member No.: 23,245 Region Association: None |
I just bought a 1973 914 1.7L and some aftermarket 8 spoke EMPI style rims came with it. I don't know the rim manufacturer. The rims are 15 inch diameter, 5.5 inch width, 4x130mm lug with a 32mm offset. Can anybody let me know what size tires are likely to fit without any modifications to the car body? Any help would be appreciated
drem914 |
Jul 11 2019, 09:14 PM
Senior Member Group: Members Posts: 1,030 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
I just bought a 1973 914 1.7L and some aftermarket 8 spoke EMPI style rims came with it. I don't know the rim manufacturer. The rims are 15 inch diameter, 5.5 inch width, 4x130mm lug with a 32mm offset. Can anybody let me know what size tires are likely to fit without any modifications to the car body? Any help would be appreciated It has been a couple years since I had sold my set after doing a 5 lug conversion and if I recall correctly they were 195/65-15 or 195/60-15 which was probably a little to wide for the wheel itself. Mine were the same kind in black. |
porschetub |
Jul 11 2019, 11:40 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I just bought a 1973 914 1.7L and some aftermarket 8 spoke EMPI style rims came with it. I don't know the rim manufacturer. The rims are 15 inch diameter, 5.5 inch width, 4x130mm lug with a 32mm offset. Can anybody let me know what size tires are likely to fit without any modifications to the car body? Any help would be appreciated It has been a couple years since I had sold my set after doing a 5 lug conversion and if I recall correctly they were 195/65-15 or 195/60-15 which was probably a little to wide for the wheel itself. Mine were the same kind in black. Seem to remember from the tyre match calculators 195 width tyre are too wide for a 5 1/2" rim however if it is a high profile tyre it works as many on here have done with factory supplied rims of the same width,just don't drop the profile too much or you will have a tyre too pumped for the rim and will throw your speedo out and provide a firmer ride also. Certain someone mentioned 195/65/15 was correct but could be wrong,body mods will never be required with these rims,cheers. |
JohnS |
Jul 12 2019, 08:14 AM
I just bought a 1973 914 1.7L and some aftermarket 8 spoke EMPI style rims came with it. I don't know the rim manufacturer. The rims are 15 inch diameter, 5.5 inch width, 4x130mm lug with a 32mm offset. Can anybody let me know what size tires are likely to fit without any modifications to the car body? Any help would be appreciated It has been a couple years since I had sold my set after doing a 5 lug conversion and if I recall correctly they were 195/65-15 or 195/60-15 which was probably a little to wide for the wheel itself. Mine were the same kind in black. Thanks for the info. |
JohnS |
Jul 12 2019, 08:15 AM
I just bought a 1973 914 1.7L and some aftermarket 8 spoke EMPI style rims came with it. I don't know the rim manufacturer. The rims are 15 inch diameter, 5.5 inch width, 4x130mm lug with a 32mm offset. Can anybody let me know what size tires are likely to fit without any modifications to the car body? Any help would be appreciated It has been a couple years since I had sold my set after doing a 5 lug conversion and if I recall correctly they were 195/65-15 or 195/60-15 which was probably a little to wide for the wheel itself. Mine were the same kind in black. Seem to remember from the tyre match calculators 195 width tyre are too wide for a 5 1/2" rim however if it is a high profile tyre it works as many on here have done with factory supplied rims of the same width,just don't drop the profile too much or you will have a tyre too pumped for the rim and will throw your speedo out and provide a firmer ride also. Certain someone mentioned 195/65/15 was correct but could be wrong,body mods will never be required with these rims,cheers. Thanks for the help. |
dr914@autoatlanta.com |
Jul 12 2019, 08:57 AM
914 Guru Group: Members Posts: 7,868 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
both wheels have a vw bug offset (I call it an outset!) so you cannot wear the widest tire. 165x15 fits for sure, but maybe 195/65x15. You would have to try these before buying, and that wider size may fit one side but not the other due to body variations. Back when the cars were new, all the dealers virtually had were 165x15 tires so selling and installing aftermarket empi wheels was easy and made them extra money
advman89 |
Jul 12 2019, 12:15 PM
Member Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest |
I have a set of 165/80 15s on my EMPIs (how can I tell if they are real?) and in need of tires. Looking for options myself!
This is what TireRack has listed: https://www.tirerack.com/tires/TireSearchRe...rearDiameter=17 "Classic" or "Vredestein" |
JFG |
Jul 12 2019, 01:48 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
avon 185/65 15" on mine. et 35. narrow body car. no tyre rub or roll when cornering. although i may need to lower the rear pressures. I haven't had a speeding ticket yet either, although now that my speedo has stopped working that may change (IMG:style_emoticons/default/dry.gif)
https://www.sspwheels.co.uk/gas-burner |
Jul 12 2019, 02:20 PM
both wheels have a vw bug offset (IMG:style_emoticons/default/agree.gif) Wrong offset for the 914, i'd be surprised if you can use 195s on them without having to roll the fenders. (IMG:style_emoticons/default/dry.gif) |
sholman5 |
Jul 12 2019, 02:32 PM
Kraut burner Group: Members Posts: 189 Joined: 11-September 16 From: Ormond beach, Fl. Member No.: 20,391 Region Association: South East States |
I have 6 1/2 x 15 minilites with 195-60-15. There is about a 1/2 inch clearance on the rear wheel well.
IronHillRestorations |
Jul 12 2019, 05:14 PM
I put 195/60's on those kind of wheels, and had one that barely rubbed the lip on one side on the rear. This was back in the day when a good 914 was still a budget car, and I didn't want to attempt to roll the lip, which hadn't done before.
I got creative and took a jig saw with a metal cutting blade and shaved a little off the lip, re-painted it and it worked out fine. The problem I have with rolling the lip is it gives a pocket to collect mud and rust causing smeg. |
Lo-Fi Version | Time is now: 21st May 2024 - 02:16 PM |
