Resealing an engine - what is needed and tips? |
Tdskip |
Jul 12 2019, 06:24 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
I have a healthy 2.0L that has been sitting for at least 5+ years that I want to put back into service. The engine is out so now would be the time to reseal it.
I was hoping to get a list of what you would recommend doing and any been there / done that lessons learned. I’ve decided to just replace the oil cooler with a new one since they are so cheap, thanks to @bbrock go that tip. Thanks! |
barefoot |
Jul 12 2019, 07:30 AM
Senior Member Group: Members Posts: 1,276 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Does it show any oil leakage indications as it sits now ?
As a minimum, oil cooler seals, push rod Viton seals, rocker cover gaskets plus any oil gallery plugs (replace with threaded plugs) |
injunmort |
Jul 12 2019, 08:35 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
I have done this just using a reinz engine gasket kit, front and rear main seals. I did not remove heads. just all pushrod tube seals, strainer oil pump/cooler, etc. any gasket without head removal. did not want to disturb piston/ring/cylinder assembly. this engine is on its third season with no oil leaks. it had sat for twenty plus years prior.
Tdskip |
Jul 12 2019, 08:47 AM
injunmort |
Jul 12 2019, 10:39 AM
I would. then you will have some extras if the need arises. the front and rear seals are not included and need to be ordered separately.
Tdskip |
Jul 12 2019, 10:45 AM
Lo-Fi Version | Time is now: 21st May 2024 - 10:23 AM |
