Standard air box for 3.2 in a 914-6, it does fit?!? |
PNW_Boxer993 |
Jul 13 2019, 07:09 PM
Newbie Group: Members Posts: 11 Joined: 8-January 17 From: Bellingham, WA Member No.: 20,738 Region Association: Pacific Northwest |
Hi all,
I purchased a 914-6 with a 3.2 motor installed. A cone filter was used instead of the standard air box. I would like to use the standard air box, and researched the forum to understand that it will fit. It appears from the photo found on this forum (thank you member) that the configuration is different, and additional breather holes were made. Below is my current configuration with the cone filter. Before taking the wrenches to it, what knowledge should I glean from this forum about making the change? Any assistance/advice would be greatly appreciated. Thank you in advance! Cheers, Tony |
Jul 13 2019, 08:33 PM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You go to your flaps, buy an 4” extension with a rubber connector (about $10-15) cut off the shaped end so just the tube remains and hose clamp to the flapper box and curved rubber intake. I went to Lowe’s and bought some 1” flat metal stock and made a bracket from the aluminum intake to the bottom of the flapper box. I used a vise to bend the stock and drilled a couple holes to bolt it together. Took an hour or two to get it all fit and assembled. I did leave the curved snorkel off the air box. It all fits nicely in the engine bay without have my to remove the lid or any engine parts.
Don’t drill any extra holes in the air box. It just adds more noise. (IMG:style_emoticons/default/welcome.png) |
Steve |
Jul 13 2019, 08:56 PM
914 Guru Group: Members Posts: 5,590 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
You go to your flaps, buy an 4” extension with a rubber connector (about $10-15) cut off the shaped end so just the tube remains and hose clamp to the flapper box and curved rubber intake. I went to Lowe’s and bought some 1” flat metal stock and made a bracket from the aluminum intake to the bottom of the flapper box. I used a vise to bend the stock and drilled a couple holes to bolt it together. Took an hour or two to get it all fit and assembled. I did leave the curved snorkel off the air box. It all fits nicely in the engine bay without have my to remove the lid or any engine parts. Don’t drill any extra holes in the air box. It just adds more noise. (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/agree.gif) That’s my car with the stock air box. I bought the 4” extension from Pep Boys. The assorted L brackets were Home Depot. I read in some Porsche magazine to cut the holes if you wanted more intake sound. |
Jul 13 2019, 09:11 PM
You go to your flaps, buy an 4” extension with a rubber connector (about $10-15) cut off the shaped end so just the tube remains and hose clamp to the flapper box and curved rubber intake. I went to Lowe’s and bought some 1” flat metal stock and made a bracket from the aluminum intake to the bottom of the flapper box. I used a vise to bend the stock and drilled a couple holes to bolt it together. Took an hour or two to get it all fit and assembled. I did leave the curved snorkel off the air box. It all fits nicely in the engine bay without have my to remove the lid or any engine parts. Don’t drill any extra holes in the air box. It just adds more noise. (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/agree.gif) That’s my car with the stock air box. I bought the 4” extension from Pep Boys. The assorted L brackets were Home Depot. I read in some Porsche magazine to cut the holes if you wanted more intake sound. I'm pretty sure Steve told me how to do mine. I also bought the extension from pep boys. I used my chop saw to get rid of the formed end. It's just thin plastic so the saw did it in a second.I think the snorkel got in the way of my backdated heat ducts. |
PNW_Boxer993 |
Jul 13 2019, 09:13 PM
Steve - you caught me. Thank you for the photo (IMG:style_emoticons/default/smile.gif) . I noticed that you added the holes - and now I understand why.
Mark - thank you for your reply. I have witnessed you are extremely generous with your advice - appreciate your assistance. Thank you both (IMG:style_emoticons/default/smile.gif) . Tony |
jim912928 |
Jul 14 2019, 07:44 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Here is mine...not the best picture but I used mine unmodified. ] Jim
PNW_Boxer993 |
Jul 14 2019, 09:28 AM
Thank you Jim!
burton73 |
Jul 14 2019, 11:49 AM
burton73 Group: Members Posts: 3,526 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
[quote name='mepstein' date='Jul 13 2019, 07:33 PM' post='2729882']
You go to your flaps, buy an 4” extension with a rubber connector (about $10-15) cut off the shaped end so just the tube remains and hose clamp to the flapper box and curved rubber intake. I went to Lowe’s and bought some 1” flat metal stock and made a bracket from the aluminum intake to the bottom of the flapper box. I used a vise to bend the stock and drilled a couple holes to bolt it together. Took an hour or two to get it all fit and assembled. I did leave the curved snorkel off the air box. It all fits nicely in the engine bay without have my to remove the lid or any engine parts. --------Don’t drill any extra holes in the air box. It just adds more noise.------ (IMG:style_emoticons/default/agree.gif) If you want more power, Put a Steve Wong chip in and you will be so happy. Smother and more power across the power band. You will feel the difference. I did in my 3.2 in my Carrera that is now Dax’s in Belgium Bob B |
Steve |
Jul 14 2019, 04:15 PM
scallyk9 |
Jul 14 2019, 04:28 PM
Member Group: Members Posts: 323 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest |
Thank you for this post and all the helpful information everyone. I have the 915, mb911 heat exchangers and muffler, axles, 3.2 airbox, et cetera ready to install but had to do some machining on one of the Martin Bott 916 kit parts to prevent binding. Here in the rainy Pacific Northwest, the cone intake made me nervous.
Jul 14 2019, 08:12 PM
Sounds like it’s going to be a great setup.
Lo-Fi Version | Time is now: 21st May 2024 - 02:40 PM |
