Hi all,
I purchased a 914-6 with a 3.2 motor installed. A cone filter was used instead of the standard air box. I would like to use the standard air box, and researched the forum to understand that it will fit. It appears from the photo found on this forum (thank you member) that the configuration is different, and additional breather holes were made.
Below is my current configuration with the cone filter. Before taking the wrenches to it, what knowledge should I glean from this forum about making the change? Any assistance/advice would be greatly appreciated. Thank you in advance! Cheers, Tony
