FI Wiring Harness Routing, Pics of yours? |
tvdinnerbythepool |
Jul 13 2019, 08:11 PM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Can someone post a pic of the proper way to route the FI wiring harness? Over/under what components?
Got my new one hooked up from Mr. Bowlsby but it seems like the distributor hook up is pulling a little so I'm guessing I've routed the wires the wrong way. Thx all! Side note...I HATE THE FUEL HOSES UNDER THE TANK, WHAT A PAIN IN THE ASSSSSS!!!!! (IMG:style_emoticons/default/mad.gif) |
jim_hoyland |
Jul 13 2019, 08:24 PM
Get that VIN ? Group: Members Posts: 9,303 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
QUOTE Side note...I HATE THE FUEL HOSES UNDER THE TANK, WHAT A PAIN IN THE ASSSSSS!!!!! (IMG:style_emoticons/default/mad.gif) Many have made those under tank hoses long enough such that the tank can be lifted out with hoses sttached, then set on a padded fender, then work with the hoses. Just gotta have an empty tank..... (IMG:style_emoticons/default/smile.gif) |
Superhawk996 |
Jul 14 2019, 04:45 AM
914 Guru Group: Members Posts: 5,836 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I took pictures of routing on my 2.0l
Not up on my thread but I’ll post to this one late today unless someone can get up sooner |
tvdinnerbythepool |
Jul 14 2019, 08:21 AM
Superhawk996 |
Jul 14 2019, 02:26 PM
Hmm. Not exactly crystal clear but hopefully it helps. My engine is 2.0L so not sure about applicability to other variants.
main harness routes in along passenger side. Goes to rear tin. Distributor take out spits out to rear of the tin on the passenger side of the air plenum. routes under the plenum runners. |
tvdinnerbythepool |
Jul 14 2019, 05:12 PM
Hmm. Not exactly crystal clear but hopefully it helps. My engine is 2.0L so not sure about applicability to other variants. main harness routes in along passenger side. Goes to rear tin. Distributor take out spits out to rear of the tin on the passenger side of the air plenum. routes under the plenum runners. Thank you very much! I appreciate the response |
Lo-Fi Version | Time is now: 21st May 2024 - 04:41 AM |
