1974 2.0L Fuel Injector Leak Question |
Rsjg911 |
Jul 15 2019, 01:52 AM
Member Group: Members Posts: 89 Joined: 13-June 16 From: Weston, Florida Member No.: 20,105 Region Association: South East States |
Hi Guys:
One of my 1974 2.0L fuel injectors is leaking. The injectors are original to the car which has 58,xxx miles on it. I replaced the inner and outer valve seats (seals) and upon starting the car I noticed a very fine spray coming out of the top of the outer seat/seal. I was wondering if there might be a very small crack in the injector allowing this seepage. My question is, do I need a new fuel injector? If you do recommend a replacement fuel injector, which brand do you recommend? I have seen lots of Standard Motor Products FJ67s for sale. Are they reliable? Lastly, for my car, are the following part numbers interchangeable: 039 906 031 vs 039 906 031 A? Thank you so much and Keep 'em on the Road! (IMG:style_emoticons/default/beerchug.gif) Ron |
Rsjg911 |
Jul 15 2019, 11:30 AM
Hi Guys: One of my 1974 2.0L fuel injectors is leaking. The injectors are original to the car which has 58,xxx miles on it. I replaced the inner and outer valve seats (seals) and upon starting the car I noticed a very fine spray coming out of the top of the outer seat/seal. I was wondering if there might be a very small crack in the injector allowing this seepage. My question is, do I need a new fuel injector? If you do recommend a replacement fuel injector, which brand do you recommend? I have seen lots of Standard Motor Products FJ67s for sale. Are they reliable? Lastly, for my car, are the following part numbers interchangeable: 039 906 031 vs 039 906 031 A? Thank you so much and Keep 'em on the Road! (IMG:style_emoticons/default/beerchug.gif) Ron |
mtndawg |
Jul 15 2019, 12:05 PM
Member Group: Members Posts: 413 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I’ve had injectors cleaned and tested by fuel injection Corp and WitchHunter performance. Give one of them a call and they can help.
Jul 15 2019, 12:12 PM
If it’s the injector and not the seal or hose, toss it. It’s trash.
porschetub |
Jul 15 2019, 05:29 PM
If it’s the injector and not the seal or hose, toss it. It’s trash. (IMG:style_emoticons/default/agree.gif) |
Rsjg911 |
Jul 17 2019, 10:21 AM
If it’s the injector and not the seal or hose, toss it. It’s trash. Thank you my friend. I suspect you are right so I purchased a new injector. It should arrive tomorrow. (IMG:style_emoticons/default/piratenanner.gif) |
Rsjg911 |
Jul 17 2019, 10:22 AM
If it’s the injector and not the seal or hose, toss it. It’s trash. (IMG:style_emoticons/default/agree.gif) Thanks!! (IMG:style_emoticons/default/beerchug.gif) |
dr914@autoatlanta.com |
Jul 17 2019, 12:07 PM
914 Guru Group: Members Posts: 7,817 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
if leaking between the green and black part of the body, it will need to be rebuilt. If leaking at the hose or crimped hose fitting, you can easily clip off the fitting and install a new bent hose. Fuel injection can rebuild them easily
Lo-Fi Version | Time is now: 26th April 2024 - 12:14 AM |
