Thoughts on bending plastic brake reservior lines, 914-6 project |
tailwind22 |
Jul 18 2019, 12:30 PM
Member Group: Members Posts: 88 Joined: 7-November 17 From: Moses Lake, WA Member No.: 21,583 Region Association: Pacific Northwest |
Working on my 70 914-6 resto and the plastic brake reservoir feed lines that I have need a little work in the bends for a better fit. I tried to use a hot air gun but didn't have a lot of luck with the bends in the plastic lines. Anyone have suggestions?
bbrock |
Jul 18 2019, 03:33 PM
Yeah, get ready to fill the swear jar. Worst job on my project so far. (IMG:style_emoticons/default/mad.gif)
I did manage to use a heat gun to get the bends in but it takes time, patience, and patience. I didn't get the bends perfect and don't think it is necessary. Get them close and then use the metal strip hold downs to hold it in place. Getting those fittings that go into the MC on is where the swearing starts. There is nothing fun about those lines. |
914Sixer |
Jul 18 2019, 04:05 PM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Put a want to buy, should be easy to find some. Not an item that is sold very often, usually end up in the trash.
tailwind22 |
Jul 18 2019, 04:39 PM
I've got mine correctly situated in the MC (yes, with considerable swearing) so not going to try to find a better fitting set. I think I only need to make some small progress. I probably did not heat up enough.
Chris914n6 |
Jul 18 2019, 04:53 PM
Jackstands are my life. Group: Members Posts: 3,321 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
What makes you think the vinyl tubing was bent into shape in the first place?
aturboman |
Jul 18 2019, 05:09 PM
Member Group: Members Posts: 135 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
They were, NOS piece. It's Polymide tubing, same material as early CIS fuel lines. |
raynekat |
Jul 18 2019, 07:40 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
I agree, that they came that way (bent) from the factory.
I recently bought some factory tubing from the dealer and both pieces had similar bends as the pic above. IMHO....The type and number of bends just wouldn't happen naturally to a straight piece of plastic tubing over time. |
JeffBowlsby |
Jul 18 2019, 07:53 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Polyamide is nylon. Insert a thick gage copper wire as a mold. Use a heat gun and hold it until it cools down.
tailwind22 |
Jul 19 2019, 06:43 AM
90quattrocoupe |
Jul 19 2019, 03:41 PM
Member Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California |
You can also use spring benders. Slide the tubing into the bender, bend tubing to shape, heat bender enough to warm nylon tube, let cool with the bender on it and remove bender. It should hold the shape.
(IMG:http://www.914world.com/bbs2/uploads_offsite/mobileimages.lowes.com-20561-1563572490.1.jpg) Greg W. |
Lo-Fi Version | Time is now: 21st May 2024 - 04:30 AM |
