1971 Bumper removal |
advman89 |
Jul 19 2019, 08:22 AM
Member Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest |
I need to remove my front bumper...it is as simple as unbolting from the wheel well arches? Been looking for some instruction, but it might be one of those overly simple things I'm just missing.
dr914@autoatlanta.com |
Jul 19 2019, 08:28 AM
914 Guru Group: Members Posts: 7,868 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
turn the wheel all the way to the right then look in front of the left front wheel and see the two 13mm headed bolts and unscrew, then turn the wheel all of the way to the left and look in front of the left front tire and unscrew the two 13mm headed bolts while an assistant cradles the bumper. Then just move it away from the body, the rubber dog bones may be taped to the bumper or loose and fall down. You may need to squirt the bolts with wd40 or pb blaster first
I need to remove my front bumper...it is as simple as unbolting from the wheel well arches? Been looking for some instruction, but it might be one of those overly simple things I'm just missing. |
advman89 |
Jul 19 2019, 10:04 AM
Perfect. I'll give em a squirt of oil tonight...not sure if it's ever been removed and there is a lot of crud built up there.
Thank you again!! |
90quattrocoupe |
Jul 19 2019, 03:33 PM
Member Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California |
When you put them back, coat the threads of the bolts and the inside of the dog bones with copper slip.
Greg W. |
Lo-Fi Version | Time is now: 21st May 2024 - 03:59 PM |
