turn the wheel all the way to the right then look in front of the left front wheel and see the two 13mm headed bolts and unscrew, then turn the wheel all of the way to the left and look in front of the left front tire and unscrew the two 13mm headed bolts while an assistant cradles the bumper. Then just move it away from the body, the rubber dog bones may be taped to the bumper or loose and fall down. You may need to squirt the bolts with wd40 or pb blaster first
QUOTE(advman89 @ Jul 19 2019, 07:22 AM)
I need to remove my front bumper...it is as simple as unbolting from the wheel well arches? Been looking for some instruction, but it might be one of those overly simple things I'm just missing.
