74 L-Jet dies on braking |
Halfnelson |
Jul 20 2019, 08:00 AM
Newbie Group: Members Posts: 46 Joined: 31-July 17 From: Cornwall Member No.: 21,303 Region Association: England |
My 74 L-Jet has always behaved. Recently had all fuel hoses and injector seals replaced. Starts and idles well. Runs well. However when hot it dies when braking. Put the clutch in needle drops but rather than stopping at about 7-800rpm, it continues dropping to zero. It I toe heel and keep the revs up, it will then idle. Any ideas appreciated, Thanks Chris
JeffBowlsby |
Jul 20 2019, 08:18 AM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Did you replace your clutch cable recently and get it wrapped around the accelerator cable in the center tunnel?
dr914@autoatlanta.com |
Jul 20 2019, 09:05 AM
914 Guru Group: Members Posts: 7,868 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
sounds like a vacuum leak, maybe the decel valve is no longer connected. I would start by examining all of the hoses and boots to make sure all are firmly connected. Also make sure that the air flow meter flap has not started sticking when hot and that the points dwell is 50
My 74 L-Jet has always behaved. Recently had all fuel hoses and injector seals replaced. Starts and idles well. Runs well. However when hot it dies when braking. Put the clutch in needle drops but rather than stopping at about 7-800rpm, it continues dropping to zero. It I toe heel and keep the revs up, it will then idle. Any ideas appreciated, Thanks Chris |
Halfnelson |
Jul 20 2019, 11:08 AM
Halfnelson |
Jul 20 2019, 11:12 AM
sounds like a vacuum leak, maybe the decel valve is no longer connected. I would start by examining all of the hoses and boots to make sure all are firmly connected. Also make sure that the air flow meter flap has not started sticking when hot and that the points dwell is 50 Thanks - I'll check those now. Only really an issue as it gets hotter - would a sticking air flow flap need replacing or is there something that can be done to rectify? |
Lo-Fi Version | Time is now: 21st May 2024 - 02:36 PM |
