Jack point panel replacement, Quality differences? Replace panel and tube together? |
toadman |
Jul 20 2019, 04:28 PM
Member Group: Members Posts: 168 Joined: 26-December 05 From: Cincinnati, OH Member No.: 5,316 |
The jack point panel on the passenger side of my car appears to be cracked, not rusted.
This part is NLA from Porsche. Restoration Design, Sierra Madre and Auto Atlanta (maybe others) offer replacements. Does anyone know if there are any quality differences for this part among these suppliers? The panel and receiver tube are offered separately. Is it possible to replace the panel by itself or should I plan on replacing the panel and tube together? Thanks |
Cairo94507 |
Jul 20 2019, 05:15 PM
Michael Group: Members Posts: 9,772 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I am not sure what you mean by the panel. If you mean the small square-ish tube that the factory jack would go into, (see the circled part in the picture) as well as the sort of domed surround that the square tube goes into, then yes, I would replace both at the same time. If you mean the longitudinal that runs from the front to the rear of the car, that the domed piece is welded to, that depends on if the longitudinal really is solid or not. Take a grinder to it and you will see if there is rust or not. (As an aside, I had a minor anxiety attack when I looked at this picture and saw what my looked like at one point, in a galaxy far far away.) (IMG:style_emoticons/default/beerchug.gif)
Jul 20 2019, 05:18 PM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
They rust from the inside out. Remove the old one and see what you have.
toadman |
Jul 20 2019, 07:26 PM
I am not sure what you mean by the panel. If you mean the small square-ish tube that the factory jack would go into, (see the circled part in the picture) as well as the sort of domed surround that the square tube goes into, then yes, I would replace both at the same time. If you mean the longitudinal that runs from the front to the rear of the car, that the domed piece is welded to, that depends on if the longitudinal really is solid or not. Take a grinder to it and you will see if there is rust or not. (As an aside, I had a minor anxiety attack when I looked at this picture and saw what my looked like at one point, in a galaxy far far away.) (IMG:style_emoticons/default/beerchug.gif) The dome and square tube that are circled in your picture are the parts I am talking about. |
914werke |
Jul 20 2019, 09:42 PM
"I got blisters on me fingers" Group: Members Posts: 10,082 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/confused24.gif) Both are readily available replacement steel components from various sources.
A crack in the tube may mean underlying rust that may necessitate replacement of both, but not necessarily. If it is simply a crack it could be welded up with no ill effect. You are correct to be cautious as the tube is intended to support the full weight of the car when jacking with the OE Jack. |
Larmo63 |
Jul 20 2019, 09:49 PM
Pictures here might be helpful?
Just saying. |
toadman |
Jul 22 2019, 03:39 PM
Pictures here might be helpful? Just saying. I agree. Pic is attached. Lighting is not great. The dome-shaped panel is cracked. The jack receiver tube seems to be in good shape. All of the panel welds to the longitudnal also look pretty good. I have owned the car for 18 years and have never raised it using the factory jack. I always have used a floor jack and lifted at the doughnut jackpoints underneath. |
Jul 22 2019, 03:52 PM
Take the paint off. Probably rusted out from the inside. Paint doesn't rust so it looks fine until it's not. Remove the paint for a better look. Once you get the plate off, the long might need some patching. The weep hole gets clogged and holds the water and dirt against the metal.
Cairo94507 |
Jul 22 2019, 03:58 PM
If you have the desire, skills and the welder, etc, I would grind down the spot welds so you can see them better and then use a spot weld cutter drill bit and remove that piece entirely. Then grind down the longitudinal a good 4" on either side to see if you have solid metal to weld the new receiver support and tube onto. Don't be afraid to take a pick to the area and see if you can penetrate the long. Does no good to try to weld new metal to rust. Then treat the area for rust, use a good epoxy primer and then paint to match. Lots here have done this repair to their cars. If your long is good, that is a relatively easy repair. (IMG:style_emoticons/default/beerchug.gif)
bbrock |
Jul 22 2019, 04:02 PM
Take the paint off. Probably rusted out from the inside. Paint doesn't rust so it looks fine until it's not. Remove the paint for a better look. Once you get the plate off, the long might need some patching. The weep hole gets clogged and holds the water and dirt against the metal. (IMG:style_emoticons/default/agree.gif) Yeah, that's rust. I'll bet if you stab it with a screw driver it punches right through. Looks pretty minor but I agree with Mark. Yank it off and do whatever needs to be done to the long while it is still easy and cheap. Give the other side a close inspection and cleaning too. |
roblav1 |
Jul 22 2019, 08:04 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I'd cut the bottom part of it out, at the corners, and Tig in new steel. 14 or 16 gauge there.
914Sixer |
Jul 22 2019, 08:18 PM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Just cut off from the bottom of jack tube to end, see what you find. Replacing the whole thing may not be needed. Doing the top part is really tricky.
Lo-Fi Version | Time is now: 21st May 2024 - 03:55 AM |
