Anyone have experience with 914rubber sear bolsters? |
Sm914650 |
Jul 21 2019, 06:51 AM
Member Group: Members Posts: 85 Joined: 15-October 18 From: Sf Bay Area Member No.: 22,573 Region Association: Northern California |
Seat***
Have some normal rips where bolster corners off on both seats. Thinking of ordering the bolsters from 914rubber. Anyone have any experience installing these? Wondering what the process is, and whether I need to reupholster them to the seat or just fit them in. Havnt been able to get an answer as of yet. |
Jul 21 2019, 07:44 AM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I did them a couple months ago. Good product. I used weldwood contact cement and a heat gun. It takes longer than you expect but came out nice.
Attached thumbnail(s) Attached image(s) |
bbrock |
Jul 21 2019, 08:17 AM
http://www.914world.com/bbs2/index.php?s=&...st&p=900796
I have a few additional details from my experience starting here http://www.914world.com/bbs2/index.php?s=&...t&p=2684884 |
914werke |
Jul 21 2019, 09:00 AM
"I got blisters on me fingers" Group: Members Posts: 10,083 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
what about the match to the OE vinyl grain /pattern?
ConeDodger |
Jul 21 2019, 09:51 AM
Apex killer! Group: Members Posts: 23,594 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Yup...
Jul 21 2019, 10:48 AM
iankarr |
Jul 21 2019, 11:28 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,474 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
The biggest differerence is that OEM is thicker. The slightly thinner gauge of the 914Rubber material means you need to pay a little more attention to the smoothness of the foam underneath, and how it wraps around the back of the headrest. I ended up using 1/8 inch closed foam on top of the existing, and used an upholstery needle and thread to tighten the headrest area up. I did my driver's side (which was ripped) and didn't end up needing to do the passenger side (which was perfect) since the match was so close. No one has ever noticed... |
914werke |
Jul 22 2019, 11:26 AM
(IMG:style_emoticons/default/agree.gif) The biggest differerence is that OEM is thicker. I did my driver's side (which was ripped) and didn't end up needing to do the passenger side (which was perfect) since the match was so close. No one has ever noticed... I thought it was single piece already sewn together? both bolsters & back (IMG:style_emoticons/default/confused24.gif) |
Jul 22 2019, 12:04 PM
(IMG:style_emoticons/default/agree.gif) The biggest differerence is that OEM is thicker. I did my driver's side (which was ripped) and didn't end up needing to do the passenger side (which was perfect) since the match was so close. No one has ever noticed... I thought it was single piece already sewn together? both bolsters & back (IMG:style_emoticons/default/confused24.gif) It is. I think he was talking driver seat/passenger seat. The big thing I learned with upholstery is it takes time. Prep, glue drying and the little details. Don't say, I'm going to do it this weekend, Say, I'll keep working on it until it's done. |
iankarr |
Jul 22 2019, 03:02 PM
(IMG:style_emoticons/default/agree.gif) The biggest differerence is that OEM is thicker. I did my driver's side (which was ripped) and didn't end up needing to do the passenger side (which was perfect) since the match was so close. No one has ever noticed... I thought it was single piece already sewn together? both bolsters & back (IMG:style_emoticons/default/confused24.gif) Yep. The bolsters and back are one piece. I was just saying that because the material is thinner, it needs a little more finessing than OEM. After nearly 50 years, the lower bolsters on mine definitely needed additional foam to fill out the new cover. I also agree with Mark. Definitely doable as a DIY, but you need time. |
Jul 22 2019, 03:23 PM
(IMG:style_emoticons/default/agree.gif) The biggest differerence is that OEM is thicker. I did my driver's side (which was ripped) and didn't end up needing to do the passenger side (which was perfect) since the match was so close. No one has ever noticed... I thought it was single piece already sewn together? both bolsters & back (IMG:style_emoticons/default/confused24.gif) Yep. The bolsters and back are one piece. I was just saying that because the material is thinner, it needs a little more finessing than OEM. After nearly 50 years, the lower bolsters on mine definitely needed additional foam to fill out the new cover. I also agree with Mark. Definitely doable as a DIY, but you need time. I didn't need more foam but I did heat up the vinyl and do a lot of stretching. |
Lo-Fi Version | Time is now: 21st May 2024 - 07:04 PM |
