Clutch kit, Need advice |
Morph914 |
Jul 21 2019, 09:23 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I’m thinking about purchasing a Sachs disc and pressure plate, as well as a lightened (13 lbs) flywheel from a seller on Craigslist. The parts are all new in boxes, he ended up selling the car before he had a chance to install. I’m fine with the Sachs parts but the flywheel is from European Motorworks in Hawthorne CA.
What are the pros and cons of a lightened flywheel. And does anyone have experience with this specific flywheel? Thanks in advance for any input, John |
porschetub |
Jul 22 2019, 12:10 AM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Sell it to a racer,keep full weight for a street car ok.
JamesM |
Jul 22 2019, 03:33 AM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Pros = Less rotating mass, allows quicker change in RPM/better throttle response
Cons = In theory less mass to the flywheel makes getting off the line more difficult, in practice though I have not noticed it. EWM took the flywheel on mine down to around 12lbs if i recall. I like it and wouldn't worry about running it on a street car. |
Morph914 |
Jul 22 2019, 08:03 PM
Thanks for the input, I am leaning towards the purchase of the lightened flywheel, disc and pressure plate.
The current plan is to build my 1.7 to a 2056, and this will be a Sunday, fair weather car, so I should be fine. Cheers, John |
Lo-Fi Version | Time is now: 21st May 2024 - 09:27 AM |
