Ideas on vetting a gearbox before it’s installed? |
Tdskip |
Jul 22 2019, 09:42 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
One of the 2 L engines I bought came with a side shift transmission. This transmission was properly attach the engine and had the new looking but with surface corrosion from sitting fly wheel and clutch/pressure rate set up I posted separately.
So checking the oil condition and shift action both seem like obvious checks, but short of opening it up is there anything else I should be thinking about so I don’t burn the time installing a box that needs attention? Thanks! |
Jul 22 2019, 10:02 AM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Only way is to pull the stack. Dr Evil has instructions in his signature. I think it just takes a 13mm to get to it.
Moving the gearshift means nothing. The insides could still be trash. |
Tdskip |
Jul 22 2019, 10:53 AM
Hi - thanks for the note, hope you had a good weekend.
Pulling the rear cover off is pretty easy, true. That would let me look at the gear teeth and sliders etc. Seals should be done anyway I suppose. |
porschetub |
Jul 22 2019, 02:20 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
No..or atleast the Doc said that,mine is not good and have found replacement one in my country but it has no history and is rather expensive.
76-914 |
Jul 22 2019, 03:39 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Hi - thanks for the note, hope you had a good weekend. Pulling the rear cover off is pretty easy, true. That would let me look at the gear teeth and sliders etc. Seals should be done anyway I suppose. Might want to get a blanket under it to catch the the loose parts once you remove the rear cover. It's been about 7 years but I remember a stack of washers or bearing that will fall out. Heavy grease holds them in place when you reinstall the cover. (IMG:style_emoticons/default/idea.gif) |
Tdskip |
Jul 22 2019, 03:48 PM
Hi - thanks for the note, hope you had a good weekend. Pulling the rear cover off is pretty easy, true. That would let me look at the gear teeth and sliders etc. Seals should be done anyway I suppose. Might want to get a blanket under it to catch the the loose parts once you remove the rear cover. It's been about 7 years but I remember a stack of washers or bearing that will fall out. Heavy grease holds them in place when you reinstall the cover. (IMG:style_emoticons/default/idea.gif) Good tip! Been there, dropped those. It’s ok to use grease to hold them in place upon reassembly? |
gms |
Jul 23 2019, 08:41 AM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
One of the 2 L engines I bought came with a side shift transmission. This transmission was properly attach the engine and had the new looking but with surface corrosion from sitting fly wheel and clutch/pressure rate set up I posted separately. So checking the oil condition and shift action both seem like obvious checks, but short of opening it up is there anything else I should be thinking about so I don’t burn the time installing a box that needs attention? Thanks! You cannot determine the level of wear on the dog teeth and syncros by just shifting a transaxle out of the car. I highly recommend opening it up before installing in a car, it requires minimal disassembly to inspect the gear stacks. |
VaccaRabite |
Jul 23 2019, 11:39 AM
En Garde! Group: Admin Posts: 13,445 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Do you have a running car? If so bolt it up and see if it runs. You can pull and replace a transmission in an afternoon easy. Especially if the gear oil is not full of metal flake, chances are its okay in the short run.
If it makes bad noises its bad, and needs to be rebuilt anyway... If not, happy motoring. Zach |
Lo-Fi Version | Time is now: 21st May 2024 - 05:00 PM |
