Tdskip
Jul 22 2019, 09:42 AM
One of the 2 L engines I bought came with a side shift transmission. This transmission was properly attach the engine and had the new looking but with surface corrosion from sitting fly wheel and clutch/pressure rate set up I posted separately.
So checking the oil condition and shift action both seem like obvious checks, but short of opening it up is there anything else I should be thinking about so I don’t burn the time installing a box that needs attention?
Thanks!
Jul 22 2019, 10:02 AM
Only way is to pull the stack. Dr Evil has instructions in his signature. I think it just takes a 13mm to get to it.
Moving the gearshift means nothing. The insides could still be trash.
Tdskip
Jul 22 2019, 10:53 AM
Hi - thanks for the note, hope you had a good weekend.
Pulling the rear cover off is pretty easy, true. That would let me look at the gear teeth and sliders etc. Seals should be done anyway I suppose.
porschetub
Jul 22 2019, 02:20 PM
No..or atleast the Doc said that,mine is not good and have found replacement one in my country but it has no history and is rather expensive.
76-914
Jul 22 2019, 03:39 PM
QUOTE(Tdskip @ Jul 22 2019, 09:53 AM)
Might want to get a blanket under it to catch the the loose parts once you remove the rear cover. It's been about 7 years but I remember a stack of washers or bearing that will fall out. Heavy grease holds them in place when you reinstall the cover.
Tdskip
Jul 22 2019, 03:48 PM
QUOTE(76-914 @ Jul 22 2019, 04:39 PM)
Good tip! Been there, dropped those.
It’s ok to use grease to hold them in place upon reassembly?
gms
Jul 23 2019, 08:41 AM
QUOTE(Tdskip @ Jul 22 2019, 10:42 AM)
Thanks!
You cannot determine the level of wear on the dog teeth and syncros by just shifting a transaxle out of the car. I highly recommend opening it up before installing in a car, it requires minimal disassembly to inspect the gear stacks.
VaccaRabite
Jul 23 2019, 11:39 AM
Do you have a running car? If so bolt it up and see if it runs. You can pull and replace a transmission in an afternoon easy. Especially if the gear oil is not full of metal flake, chances are its okay in the short run.
If it makes bad noises its bad, and needs to be rebuilt anyway... If not, happy motoring.
Zach
