Front Brake Assembly, Can't remember and PET is not clear to me |
Highland |
Jul 22 2019, 07:23 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I can't remember the assembly when I took it apart and I can't find any clear internet depictions. Are these photos correct or do I have things backwards or upside down? There are wavy washers behind the 12 mm bolts (don't know if they're suppose to be there).
bdstone914 |
Jul 23 2019, 07:25 AM
bdstone914 Group: Members Posts: 4,525 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Highland
You have the wrong 12mm (8.8) grade bolts that attach the calipers. Should be 10.8 or higher. I have them if you cant find them locally. Looks like early two bleeder calipers. You can not install them upside down. I do not see the bleeders. Not yet installed? The wave washers are fine. I never use those bend tabs. Porsche used wave washers on most other cars. Bruce |
bbrock |
Jul 23 2019, 08:01 AM
@Highland You have the wrong 12mm (8.8) grade bolts that attach the calipers. Should be 10.8 or higher. I have them if you cant find them locally. Looks like early two bleeder calipers. You can not install them upside down. I do not see the bleeders. Not yet installed? The wave washers are fine. I never use those bend tabs. Porsche used wave washers on most other cars. Bruce Thanks for this @bdstone I hadn't noticed the factory spec 8.8 grade on the rears and 10.9 on the front. Hope to be bolting mine up this weekend so just in time. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 08:52 PM |
