FS: 1.8L L-Jet FI Harness, *****Sold****** |
jim_hoyland |
Jul 27 2019, 01:21 PM
Get that VIN ? Group: Members Posts: 9,302 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
$30 Shipped:
I took the FI harness off my car when I had a custom harness made. The casing was hard and needed replacement; I cut all the original casing off to expose the wires. All the connectors are in place, the AFM Plug is seven pin, and I labeled all the dual-relay connectors. Also, each wire has a factory number printed on it to designate its intended usage. This is a great way to go if you have a need to customize the FI harness routing. Attached image(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 10:21 AM |
