$30 Shipped:
I took the FI harness off my car when I had a custom harness made. The casing was hard and needed replacement; I cut all the original casing off to expose the wires. All the connectors are in place, the AFM Plug is seven pin, and I labeled all the dual-relay connectors.
Also, each wire has a factory number printed on it to designate its intended usage.
This is a great way to go if you have a need to customize the FI harness routing.
