Anyone recognize this swaybar set up? |
Tdskip |
Aug 3 2019, 08:18 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
dr914@autoatlanta.com |
Aug 3 2019, 09:59 AM
914 Guru Group: Members Posts: 7,872 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Well not H&H which they crudely resemble I actually do not remember the old 914 sway bar makers other than weltmeister (totally different looking) Pacesetter (totally different looking and different mounting) and H&H (a very nice bar)
Look familiar to anyone? Clearly aftermarket. Thanks! |
Tdskip |
Aug 3 2019, 10:01 AM
Good morning, thanks for the response.
Seems like they should work OK, just curious if anyone knows what they are. Hope the construction work is going OK down there. |
Jonathan Livesay |
Aug 3 2019, 12:14 PM
Senior Member Group: Members Posts: 742 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
sixnotfour |
Aug 3 2019, 12:28 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
unkl Al,,,,made some for meaney racing in the 80s....first one ive seen..
914forme |
Aug 3 2019, 04:06 PM
Looks like an H&H copy or could be some of their later stuff. Traditional H&H looks very similar but just better details.
I should have some pictures of the H&H setup in the 914-6 thread below. Pulled this from the thread for reference, you can see the difference. I trued up the holes, milling machine curly queues took a bit of the paint off each hole. I'll clean that up latter. |
Tdskip |
Aug 3 2019, 04:11 PM
Think it will work ok?
Let me see if I can get a picture of this on next to what I think is a H&H one. Thanks, and hope everyone is having a good weekend. |
914Sixer |
Aug 3 2019, 04:34 PM
914 Guru Group: Members Posts: 8,892 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Going to have to go with home built. Don't see any reason it will not work. Critical question is the diameter of the bar.
rhodyguy |
Aug 3 2019, 04:50 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
And do stock bar bushing work with it?
Tdskip |
Aug 3 2019, 05:09 PM
Looks like 19mm. Bushings with it are good where it passes through the body, replacing them if/when needed would take detective work I suppose.
914forme |
Aug 4 2019, 06:00 PM
If you have a lathe or access to one you can make the bushing out of what ever material you wish. Just remember check your material some off gas when machined and it is not a very pleasant way to die, or get sick.
You could even key a bushing out of Oilite or Oilite plus bronze, for a decent solid bearing. |
Tdskip |
Aug 4 2019, 06:20 PM
If you have a lathe or access to one you can make the bushing out of what ever material you wish. Just remember check your material some off gas when machined and it is not a very pleasant way to die, or get sick. You could even key a bushing out of Oilite or Oilite plus bronze, for a decent solid bearing. Yikes, thanks for the heads up. |
sixnotfour |
Aug 4 2019, 06:48 PM
check the rod ends for slop. the chatter will drive even more crazy...than me...haha
gandalf_025 |
Aug 5 2019, 07:40 AM
Senior Member Group: Members Posts: 1,456 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
Found this on another site and cleaned it up a little.
Tdskip |
Aug 5 2019, 09:25 AM
Thanks - that sure looks familiar.
maf914 |
Aug 6 2019, 07:36 AM
Found this on another site and cleaned it up a little. I bought H&H sway bars and have the original copy of the H&H installation instructions including that diagram. This was old school printing. Blue/purple mimeograph on yellow paper. Hard to make decent photo copies from it. This was from 1979. The front H&H 19mm sway bar kit was $85 and the rear 16mm kit was $62. Shipping was $6. (IMG:style_emoticons/default/laugh.gif) |
914_teener |
Aug 6 2019, 11:21 AM
914 Guru Group: Members Posts: 5,200 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Think it will work ok? Let me see if I can get a picture of this on next to what I think is a H&H one. Thanks, and hope everyone is having a good weekend. Depending on the tire and front end setup that may work well on a -6. For a -4 I'd think that size bar is too much. Just my opinion about "will it work". The stock bar diameter is just fine on a -4 from my experience. |
Tdskip |
Aug 6 2019, 11:48 AM
Think it will work ok? Let me see if I can get a picture of this on next to what I think is a H&H one. Thanks, and hope everyone is having a good weekend. Depending on the tire and front end setup that may work well on a -6. For a -4 I'd think that size bar is too much. Just my opinion about "will it work". The stock bar diameter is just fine on a -4 from my experience. Hi Rob, thanks for the response. I've seen cars ruined by making them overly stiff in how they handle, thanks for raising the consideration. |
maf914 |
Aug 6 2019, 03:22 PM
For a -4 I'd think that size bar is too much. Just my opinion about "will it work". For aftermarket sway bars, 19mm was a fairly common size. Weltmeister and H&H both offered 19mm bars and also had 22mm bars as well. Tarett currently offers 19mm and 22mm bars. These bars all have adjustable sway bar arms (Lever arms) which allow the roll stiffness to be altered. My car initially had no sway bars. I added H&H sway bars, 19mm front and 16mm rear, and in my opinion, they greatly improved the handling. |
Lo-Fi Version | Time is now: 25th May 2024 - 06:01 AM |
