Need Rear Blower Hose Lengths For Both Sides, Original Plastic Hose Please |
914Sixer |
Aug 8 2019, 03:09 PM
I have been doing some research on a product I found. I wanted blower hose material that closely represented the original plastic. Well I think I have found it , its made by Webasto the people that made the gas heaters for VW and Porsche. I have some coming in from Germany. Correct 55mm diameter, foil interior and black plastic outside. Rated for 250 degrees, overkill perhaps, but going for the look. Had to buy in bulk to get price down. Should have some to sell on a limited basis. Going to see how it works out.
German Hose not China Attached image(s) |
dr914@autoatlanta.com |
Aug 8 2019, 03:11 PM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
that "stuff" is commonly available and we have the 55mm on the shelf. However the original blower hose was plastic with molded smooth ends to hold a hose clamp and was much more flexible than the part you pictured. Hence we use motormite brand hose and it seems to be suffice (of course does not perfectly resemble stock that is for sure
I have been doing some research on a product I found. I wanted blower hose material that closely represented the original plastic. Well I think I have found it , its made by Webasto the people that made the gas heaters for VW and Porsche. I have some coming in from Germany. Correct 55mm diameter, foil interior and black plastic outside. Rated for 250 degrees, overkill perhaps. But going for the look. Had to buy in bulk to get price down. Should have some to sell on a limited basis. Going to see how it works out. German Hose not China |
76-914 |
Aug 8 2019, 03:25 PM
Question; was it always the plastic hose or did earlier models use the foil lined hose??? (IMG:style_emoticons/default/confused24.gif)
Aug 8 2019, 03:40 PM
always always plastic. The very early cars has a heat riser hose 55mm going into the air cleaner from a funnel on the rear sheetmetal for faster warm up. 70-72 had the top of the engine mounted blower fan with a short hose with two different sized openings and a long hose with the same sized openings. 73-early 75 had a body mounted fan with a short hose only with two same sized openings. The right j pipe was capped off. Late 75 and 76 had two hoses a long one (just like the earlier cars) and a short one, both connected to a branch on the blower
Question; was it always the plastic hose or did earlier models use the foil lined hose??? (IMG:style_emoticons/default/confused24.gif) |
76-914 |
Aug 8 2019, 04:51 PM
(IMG:style_emoticons/default/thumb3d.gif) So noted.
Lo-Fi Version | Time is now: 18th May 2024 - 04:09 PM |
