Need Massive Help, Case failure |
Mblizzard |
Aug 9 2019, 05:32 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Ok so some of you may know I am doing the build of my life.
Put the case together for checking fit all went fine everything turned great. Disassembled and found this break in the case at the cam. I have a massive amount of money in this case and it is opened for my 102s. Anyone think of if and where I can get this repaired quickly? |
Mblizzard |
Aug 12 2019, 08:28 AM
Ok so now I am trying to find someone that can open up my case for the 102's this week.
Looks like Len can do it! (IMG:style_emoticons/default/smile.gif) Packing it up and sending to him! |
Jetsetsurfshop |
Aug 13 2019, 08:02 AM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Ok so now I am trying to find someone that can open up my case for the 102's this week. Looks like Len can do it! (IMG:style_emoticons/default/smile.gif) Packing it up and sending to him! So is Len fixing it or are you sending him a different case to start over with? Something else, I wouldn't rush an engine build. When I put a 78mm crank in my case I must have assembled and disassembled ten times to check all clearances. Taking your time will pay off in the end. (IMG:style_emoticons/default/biggrin.gif) |
Mblizzard |
Aug 13 2019, 08:04 AM
Ok so now I am trying to find someone that can open up my case for the 102's this week. Looks like Len can do it! (IMG:style_emoticons/default/smile.gif) Packing it up and sending to him! So is Len fixing it or are you sending him a different case to start over with? Something else, I wouldn't rush an engine build. When I put a 78mm crank in my case I must have assembled and disassembled ten times to check all clearances. Taking your time will pay off in the end. (IMG:style_emoticons/default/biggrin.gif) Starting over on new case. Will likely send to Chris at some point to look at fixing. |
Jetsetsurfshop |
Aug 13 2019, 08:24 AM
Ok so now I am trying to find someone that can open up my case for the 102's this week. Looks like Len can do it! (IMG:style_emoticons/default/smile.gif) Packing it up and sending to him! So is Len fixing it or are you sending him a different case to start over with? Something else, I wouldn't rush an engine build. When I put a 78mm crank in my case I must have assembled and disassembled ten times to check all clearances. Taking your time will pay off in the end. (IMG:style_emoticons/default/biggrin.gif) Starting over on new case. Will likely send to Chris at some point to look at fixing. What crank are you using? |
Lo-Fi Version | Time is now: 21st May 2024 - 04:49 PM |
