Need Massive Help, Case failure |
Mblizzard |
Aug 9 2019, 05:32 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Ok so some of you may know I am doing the build of my life.
Put the case together for checking fit all went fine everything turned great. Disassembled and found this break in the case at the cam. I have a massive amount of money in this case and it is opened for my 102s. Anyone think of if and where I can get this repaired quickly? |
Valy |
Aug 10 2019, 01:41 AM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Ok so some of you may know I am doing the build of my life. Put the case together for checking fit all went fine everything turned great. Disassembled and found this break in the case at the cam. I have a massive amount of money in this case and it is opened for my 102s. Anyone think of if and where I can get this repaired quickly? It can be repaired but not cheap as you need to weld and rebore the bearing seat. But,do I see a hairline crack between the cam bearing and the left pushrod tube hole? |
Lo-Fi Version | Time is now: 3rd May 2024 - 07:11 AM |
