Need Massive Help, Case failure |
Mblizzard |
Aug 9 2019, 05:32 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Ok so some of you may know I am doing the build of my life.
Put the case together for checking fit all went fine everything turned great. Disassembled and found this break in the case at the cam. I have a massive amount of money in this case and it is opened for my 102s. Anyone think of if and where I can get this repaired quickly? |
ChrisFoley |
Aug 10 2019, 10:45 AM
I am Tangerine Racing Group: Members Posts: 7,920 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I would repair it if it was mine.
Careful build-up with TIG, no use trying to weld the broken bit back on. Then hand grind/file/scrape until a custom made gauge pin barely fit through the bore - always being careful to not cut into the remaining original bore surface nearby. I wouldn't use a reamer - too much chance of removing material from the other case half. 1 hour for the weld process and another 3-4 hours of hand work. Tedious, but doable and worth it to recover the investment. |
Mblizzard |
Aug 10 2019, 05:52 PM
I would repair it if it was mine. Careful build-up with TIG, no use trying to weld the broken bit back on. Then hand grind/file/scrape until a custom made gauge pin barely fit through the bore - always being careful to not cut into the remaining original bore surface nearby. I wouldn't use a reamer - too much chance of removing material from the other case half. 1 hour for the weld process and another 3-4 hours of hand work. Tedious, but doable and worth it to recover the investment. Chris I would love to hear a recommendation on who could do this. |
Lo-Fi Version | Time is now: 3rd May 2024 - 08:31 AM |
