Need Massive Help, Case failure |
Mblizzard |
Aug 9 2019, 05:32 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Ok so some of you may know I am doing the build of my life.
Put the case together for checking fit all went fine everything turned great. Disassembled and found this break in the case at the cam. I have a massive amount of money in this case and it is opened for my 102s. Anyone think of if and where I can get this repaired quickly? |
porschetub |
Aug 11 2019, 12:36 AM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Now that is sh#t luck after all you have been through,as an engineer I wouldn't even go for a repair on that case its a real gamble to get it 100%,well at least 914 cases are cheap but that helps little considering the machining work that has gone into that one.
I haven't done a T4 build for a while but currently doing one and TBO its not what you call cheap,have better luck mate (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:09 AM |
