Need Massive Help, Case failure |
Mblizzard |
Aug 9 2019, 05:32 PM
Ok so some of you may know I am doing the build of my life.
Put the case together for checking fit all went fine everything turned great. Disassembled and found this break in the case at the cam. I have a massive amount of money in this case and it is opened for my 102s. Anyone think of if and where I can get this repaired quickly? |
Mark Henry |
Aug 11 2019, 08:41 AM
You don't need to timesert the case headstuds threads, I've never had an issue. but you should get a thread reforming tap to run through them before installing the ARP studs. My case isn't shuffle pined as well.
Only issue I've had is leaking ARP case through bolts, I recommend a good sealant under the washers like threebond (Yamabond4) or loctite 5900. As for making the show, give it a go but there will be other shows. Last thing you want is a fuch up because you rushed through things. |
Lo-Fi Version | Time is now: 3rd May 2024 - 04:13 AM |
