Need Massive Help, Case failure |
Mblizzard |
Aug 9 2019, 05:32 PM
Ok so some of you may know I am doing the build of my life.
Put the case together for checking fit all went fine everything turned great. Disassembled and found this break in the case at the cam. I have a massive amount of money in this case and it is opened for my 102s. Anyone think of if and where I can get this repaired quickly? |
ChrisFoley |
Aug 10 2019, 10:45 AM
I am Tangerine Racing Group: Members Posts: 7,920 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I would repair it if it was mine.
Careful build-up with TIG, no use trying to weld the broken bit back on. Then hand grind/file/scrape until a custom made gauge pin barely fit through the bore - always being careful to not cut into the remaining original bore surface nearby. I wouldn't use a reamer - too much chance of removing material from the other case half. 1 hour for the weld process and another 3-4 hours of hand work. Tedious, but doable and worth it to recover the investment. |
Mblizzard |
Aug 10 2019, 05:52 PM
I would repair it if it was mine. Careful build-up with TIG, no use trying to weld the broken bit back on. Then hand grind/file/scrape until a custom made gauge pin barely fit through the bore - always being careful to not cut into the remaining original bore surface nearby. I wouldn't use a reamer - too much chance of removing material from the other case half. 1 hour for the weld process and another 3-4 hours of hand work. Tedious, but doable and worth it to recover the investment. Chris I would love to hear a recommendation on who could do this. |
ChrisFoley |
Aug 11 2019, 09:20 AM
I would repair it if it was mine. Careful build-up with TIG, no use trying to weld the broken bit back on. Then hand grind/file/scrape until a custom made gauge pin barely fit through the bore - always being careful to not cut into the remaining original bore surface nearby. I wouldn't use a reamer - too much chance of removing material from the other case half. 1 hour for the weld process and another 3-4 hours of hand work. Tedious, but doable and worth it to recover the investment. Chris I would love to hear a recommendation on who could do this. Metal craftsmen with the required tools and skills aren't too common nowadays I suppose. Someone who restores antique cars maybe? An old machine shop that also does welding? Someone who likes to work with his hands and has plenty of patience. If its going to be a back-up and you don't mind waiting a few months, you can send it to me. |
Lo-Fi Version | Time is now: 3rd May 2024 - 12:20 AM |
