3 Pages V < 1 2 3 >
> Need Massive Help, Case failure
Bills914-4
post Aug 10 2019, 04:09 PM
Post #21
Damn, so sorry Mike , you have alot of work in that case , timeserts, bore for 102's,
shuffle pins, ect, , I might try and save it , I would put a correct dia. (cam bearing o.d.)
bar in the cam bore , v-out the crack inside ,pull the piece back against the bar with
small clamp gently , Weld the outside crack let it cool ,remove clamp & bar , then
weld the v-grooved crack , once it's cooled dremel down the weld , check it by
sliding the Bar back towards the welded cam saddle seeing if the bar stops , using
it as a gage , clearance it until it slides in smoothly , then assemble the case with
cam+bearings only , torque it down little by little checking for cam binding by tuning
the cam , then mill file the parting surface to match , just another idea Bill D.
ps you can hold the bar in the cam saddles with a couple of straps going thru
the cylinder bores and around a wood 2x2 ,
flyer86d
post Aug 10 2019, 04:55 PM
Post #22
QUOTE(ChrisFoley @ Aug 10 2019, 12:45 PM) *
I would repair it if it was mine.
Careful build-up with TIG, no use trying to weld the broken bit back on. Then hand grind/file/scrape until a custom made gauge pin barely fit through the bore - always being careful to not cut into the remaining original bore surface nearby.
I wouldn't use a reamer - too much chance of removing material from the other case half.
1 hour for the weld process and another 3-4 hours of hand work.
Tedious, but doable and worth it to recover the investment.
That is the way to go. It is not the end of the world.
Charlie
Rand
post Aug 10 2019, 04:58 PM
Post #23
Cross Member
Sometimes we expect too much of an old thing. Please don't dump any huge money after bad. Are you insistent on TIV? If so, trust Chris.
Mblizzard
post Aug 10 2019, 05:51 PM
Post #24
All good advice. But I think I am going to see if I can get another case opened for the 102s and uild from there.
I am also going to have this case fixed and build a backup engine.
Crap I hope someone can complete the case quickly.
George I may be calling you to get some recommendations.
After looking at things for a long time I think that when the crank broke it sent a lot of shock to the cam and stressed this rea. New bearings and can’t just stressed the area and it failed.
Really have to pull one out of May ass to make it by Okteenerfest.
Mblizzard
post Aug 10 2019, 05:52 PM
Post #25
QUOTE(ChrisFoley @ Aug 10 2019, 08:45 AM) *
Chris I would love to hear a recommendation on who could do this.
post Aug 10 2019, 06:48 PM
Post #26
914-6 GT in waiting
Mike - I know you really really want to get your engine done in time for Octeenerfest but I would look at plan B. Building an engine on a short deadline is never a good idea, especially when it's a custom build. Take your time, enjoy the build and enjoy Octeenerfest.
rhodyguy
post Aug 10 2019, 08:45 PM
Post #27
(IMG:style_emoticons/default/agree.gif) a replacement case is the least expensive component at this point. A failure could be catastrophic. Would it be in the back of your mind every time you drove the car?
porschetub
post Aug 11 2019, 12:36 AM
Post #28
Now that is sh#t luck after all you have been through,as an engineer I wouldn't even go for a repair on that case its a real gamble to get it 100%,well at least 914 cases are cheap but that helps little considering the machining work that has gone into that one.
I haven't done a T4 build for a while but currently doing one and TBO its not what you call cheap,have better luck mate (IMG:style_emoticons/default/beerchug.gif)
Mblizzard
post Aug 11 2019, 08:17 AM
Post #29
Any suggestions on who could bore out the case to 102 quickly?
Mark Henry
post Aug 11 2019, 08:41 AM
Post #30
that's what I do!
You don't need to timesert the case headstuds threads, I've never had an issue. but you should get a thread reforming tap to run through them before installing the ARP studs. My case isn't shuffle pined as well.
Only issue I've had is leaking ARP case through bolts, I recommend a good sealant under the washers like threebond (Yamabond4) or loctite 5900.
As for making the show, give it a go but there will be other shows. Last thing you want is a fuch up because you rushed through things.
ChrisFoley
post Aug 11 2019, 09:20 AM
Post #31
I am Tangerine Racing
QUOTE(Mblizzard @ Aug 10 2019, 06:52 PM) *
Metal craftsmen with the required tools and skills aren't too common nowadays I suppose.
Someone who restores antique cars maybe? An old machine shop that also does welding?
Someone who likes to work with his hands and has plenty of patience.
If its going to be a back-up and you don't mind waiting a few months, you can send it to me.
bdstone914
post Aug 11 2019, 09:32 AM
Post #32
bdstone914
@mblizzard
Mike, I would contact George at European Motorworks in Hawthorne CA.
He had over 300 cases there. He has been building Type Iv motors for decades and is reasonable. Could probably get you a case of send all the long block guts to him and have him build it. He did a 2056cc long block for me years ago for $300 assemble including balancing. Motor still pulling 6500rpms on a tracked car.
Address: 13224 Prairie Ave, Hawthorne, CA 90250
Hours: Closed ⋅ Opens 9AM Monday
Phone: (310) 644-8038
Bruce
Mblizzard
post Aug 11 2019, 06:42 PM
Post #33
QUOTE(ChrisFoley @ Aug 11 2019, 07:20 AM) *
That’s an easy choice. I will send it to you!
Larmo63
post Aug 11 2019, 10:45 PM
Post #34
I second the Jorge recommendation if you need it quickly.
He does fast turnaround.
Mblizzard
post Aug 12 2019, 08:28 AM
Post #35
Ok so now I am trying to find someone that can open up my case for the 102's this week.
Looks like Len can do it! (IMG:style_emoticons/default/smile.gif)
Packing it up and sending to him!
Betty
post Aug 12 2019, 09:12 PM
Post #36
Driver
QUOTE(Mblizzard @ Aug 12 2019, 09:28 AM) *
(IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif)
Jetsetsurfshop
post Aug 13 2019, 08:02 AM
Post #37
QUOTE(Mblizzard @ Aug 12 2019, 06:28 AM) *
So is Len fixing it or are you sending him a different case to start over with?
Something else, I wouldn't rush an engine build. When I put a 78mm crank in my case I must have assembled and disassembled ten times to check all clearances. Taking your time will pay off in the end. (IMG:style_emoticons/default/biggrin.gif)
Mblizzard
post Aug 13 2019, 08:04 AM
Post #38
QUOTE(Jetsetsurfshop @ Aug 13 2019, 06:02 AM) *
Starting over on new case. Will likely send to Chris at some point to look at fixing.
Jetsetsurfshop
post Aug 13 2019, 08:24 AM
Post #39
QUOTE(Mblizzard @ Aug 13 2019, 06:04 AM) *
What crank are you using?
Mblizzard
post Aug 13 2019, 09:35 AM
Post #40
QUOTE(Jetsetsurfshop @ Aug 13 2019, 06:24 AM) *
78mm from Type 4 store. The assembly and disassembly is exactly what I did on the first go. There were very few clearance issues.
3 Pages V < 1 2 3 >
- Lo-Fi Version Time is now: 4th June 2026 - 12:12 AM
