Any tips on setting up a Hex bar for dual Webers? |
Tdskip |
Aug 15 2019, 11:17 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hi guys - I'm going to swap out the giant single Weber that is currently on the aka Turbo car for two properly sized Webers soon and I wanted to ask if there are any tips / techniques etc for getting the hex part set up properly.
It doesn't look that complicated but the searching I've don't suggests there is some heartburn that some people encounter. Thanks! |
ConeDodger |
Aug 15 2019, 12:53 PM
Apex killer! Group: Members Posts: 23,578 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Call @McMark . He has very accurate linkage that synchs easily. Hex bar is junk for tuning and carbs are hard enough!
Carl La Fong |
Aug 15 2019, 01:18 PM
Member Group: Retired Members Posts: 137 Joined: 27-March 19 From: west Member No.: 23,000 Region Association: None |
With all due respect to McMark and Cone Dodger, I have used a hex bar set up for the past 14 years with great success. Set up properly, as mine are, both throttles open simultaneously, reach WOT at the same time with NO play in the linkage at all. Linkage geometry is the same on both carbs. McMark makes great stuff but if you already have the hex bar, it can be made to work just fine. (IMG:style_emoticons/default/smile.gif) .
Tdskip |
Aug 15 2019, 01:32 PM
I already have all the bits, so would like to make what I have work (please).
Mark Henry |
Aug 15 2019, 01:33 PM
But I can tell you that's a lousy set up because the drop links are not square to the throttle shafts. (IMG:style_emoticons/default/wink.gif)
sixnotfour |
Aug 15 2019, 01:42 PM
914 Wizard Group: Members Posts: 10,422 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
http://www.empius.com/Instructions/99-4428-0.pdf
https://www.youtube.com/watch?v=r2hkBh4nkTM the newer version has stand offs to make arms straighter https://www.youtube.com/watch?v=r2hkBh4nkTM |
Tdskip |
Aug 15 2019, 02:01 PM
michael7810 |
Aug 15 2019, 02:17 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
With all due respect to McMark and Cone Dodger, I have used a hex bar set up for the past 14 years with great success. Set up properly, as mine are, both throttles open simultaneously, reach WOT at the same time with NO play in the linkage at all. Linkage geometry is the same on both carbs. McMark makes great stuff but if you already have the hex bar, it can be made to work just fine. (IMG:style_emoticons/default/smile.gif) . I agree with |
johnhora |
Aug 15 2019, 02:29 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Tdskip...
please take a pic of what you have it will help us see what you are dealing with both systems will work..it takes time on each...I've used and tuned both and if you already have the parts why not give them a try and save some money right as you probably know the problem with boxer engine is the offset of the intake ports at the heads... thus the carbs are not directly across from each other and the crossbar and other linkage arrangements have to compensate for this angle. this same problem has plagued the VW hotrods for ages way before type 4 engines some have created offset intake manifolds and air cleaners with offset bracket post... CB Performance comes to mind on these...they've making some nice stuff for ever. the thing on the crossbar is it works best if it's straight across the engine as can be... then the drop links don't bind as much... the real thing to tuning is to not have any linkage attached to the carbs while dialing in...then attach the linkage with as little bind as possible. And yes you can run a engine with out any linkage attached if you have preset your carbs....just blip the carb on #1 side...it's where your going to start anyway Probably the best book on this is the Weber Tech Manual, by Bob Tomlinson The Key is Patience My Brother! (IMG:style_emoticons/default/smile.gif) |
Tdskip |
Aug 15 2019, 03:12 PM
Thanks gentlemen, will take my time and make sure they are dialed-in prior to attaching the crossbar.
Carl La Fong |
Aug 15 2019, 04:09 PM
But I can tell you that's a lousy set up because the drop links are not square to the throttle shafts. (IMG:style_emoticons/default/wink.gif) Both throttles open at the same time at the same rate and reach WOT at exactly the same time. I know it works that way because I looked at the throttles when my wife pushed on the "pedal on the right". Nothing was working until I realized she was pushing on the brake. When she discovered where the "pedal on the right was", everything worked as I described. |
rhodyguy |
Aug 15 2019, 04:36 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,073 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Buy one from Triad. For reasons too newmerous to list. When shopping, ask if the throttle cable holder is included. Be prepared to Fab up one if you go the CB route. You may have to shorten the crossbar too. I did when I bought one. The end springs suck. Dave is a member/vendor.
sixnotfour |
Aug 15 2019, 04:48 PM
Let us not forget ,,,,,we are cheep .....let him run what he has,,hell ...He will probably sell it....
It's good enough for where he is in the 914 world..,? . |
Lo-Fi Version | Time is now: 7th May 2024 - 08:55 AM |
