Tdskip...
please take a pic of what you have it will help us see what you are dealing with
both systems will work..it takes time on each...I've used and tuned both
and if you already have the parts why not give them a try and save some money right
as you probably know the problem with boxer engine is the offset of the intake ports at the heads...
thus the carbs are not directly across from each other and the crossbar and other linkage arrangements have to compensate for this angle.
this same problem has plagued the VW hotrods for ages way before type 4 engines
some have created offset intake manifolds and air cleaners with offset bracket post...
CB Performance comes to mind on these...they've making some nice stuff for ever.
the thing on the crossbar is it works best if it's straight across the engine as can be...
then the drop links don't bind as much...
the real thing to tuning is to not have any linkage attached to the carbs while dialing in...then attach the linkage with as little bind as possible.
And yes you can run a engine with out any linkage attached if you have preset your carbs....just blip the carb on #1 side...it's where your going to start anyway
Probably the best book on this is the Weber Tech Manual, by Bob Tomlinson
The Key is Patience My Brother!
