Mallory Unilite Test Procedure |
yeahmag |
Aug 16 2019, 10:46 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I just had (I believe) my Unilite Optical Module fail. I want to make sure I'm testing it right. Off the car I'm doing the following:
12V + to red wire 12V - to brown wire Test voltage at green wire with the optical slot covered and open (with credit card or the like). On the green wire I have effectively no voltage. Assuming I did the test correctly, this means it's toast. Which is strange as it's lasted probably 10+ years (I run the 6AL and the protection circuit). I'm replacing the very expensive 605 module with what seems to be a more cost effective unit, the 6100M. I'd love to test it before putting it in the car, so let me know if I have the procedure down correctly. Thanks. |
Lo-Fi Version | Time is now: 18th May 2024 - 07:27 PM |
