Alternater Problem?, 1971 1.7L |
milwlandrover |
Aug 16 2019, 02:06 PM
Member Group: Members Posts: 149 Joined: 22-June 12 From: Greendale Wisconsin Member No.: 14,592 Region Association: Upper MidWest |
I took my car out for a ride and it was running well. The green alternator light came on at start and then went off while running. I got to the other side of town and the car died. It turned over slowly but would not start. I tried jumping it and it would not start.
I took the battery out and took it home and charged it over night. The voltage read 10.8 volts. before charging. I reinstalled once fully charged and it started right up. I drove it home and the voltage when I got there was 10.6volts. I charged it again fully and tested it on a small load tester at 560cca. and it shows a good battery. I installed it and tested the voltage while running and I got 12.6 volts. I'm thinking it is a voltage regulator problem (I will stop and get a new one on the way home) or an Alternator problem. Any other ideas? As always I am thanking you for your help. Cheers! markw |
ejm |
Aug 16 2019, 05:02 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,692 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Spoke |
Aug 16 2019, 05:49 PM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Check the alternator belt first.
If the alternator belt is ok, check the following voltages: All 3 pins on the VR as they come off of the alternator. Measure all 3 with respect to chassis ground with the engine running. Check battery voltage from BATT+ to chassis. Let us know what you find. This will go a long way to finding the issue. |
Lo-Fi Version | Time is now: 19th May 2024 - 06:43 PM |
