Front lower targa top seal |
partwerks |
Aug 17 2019, 03:39 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Seems hard getting the front lower targa top seal to fit in.
Any thoughts, ideas, or suggestions to help. |
dr914@autoatlanta.com |
Aug 17 2019, 03:48 PM
914 Guru Group: Members Posts: 7,832 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
partwerks |
Aug 17 2019, 03:53 PM
you may need to trim it a bit, has a rectangular notch in the middle, a bit of silicone grease helps as well Seems hard getting the front lower targa top seal to fit in. Any thoughts, ideas, or suggestions to help. I've got it started, since I got that squarish part started in. Since you've probably done lots of these, do I trim the ends square to fit in the corners? With that center piece in the middle, there isn't much more than 1/8" in between, and looks like I am going to have to cut deeper into that notch to allow it to fit down in that narrow groove, or will it prove anything to remove that block, put the seal in, and then reinstall that center block? |
Lo-Fi Version | Time is now: 4th May 2024 - 12:36 AM |
