Front lower targa top seal |
partwerks |
Aug 17 2019, 03:39 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Seems hard getting the front lower targa top seal to fit in.
Any thoughts, ideas, or suggestions to help. |
Mikey914 |
Aug 17 2019, 09:27 PM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
By the way the "head" has a flap at the bottom that goes over the textured vinyl upper that the visor clips go into.
It hides the edge by going over it. |
FlacaProductions |
Aug 18 2019, 09:19 AM
Senior Member Group: Members Posts: 1,570 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
@Mikey914 - can you run through this part again - I don't quite understand. I just received your targa seal kit and it's on the short list for install. Just trying to get it in my head before I make the attempt.
By the way the "head" has a flap at the bottom that goes over the textured vinyl upper that the visor clips go into. It hides the edge by going over it. |
partwerks |
Aug 18 2019, 03:21 PM
@Mikey914 - can you run through this part again - I don't quite understand. I just received your targa seal kit and it's on the short list for install. Just trying to get it in my head before I make the attempt. By the way the "head" has a flap at the bottom that goes over the textured vinyl upper that the visor clips go into. It hides the edge by going over it. I think he is talking about that bottom lip you just pull over that texture skin on the moulding so that it hides it. Most likely you will have to carve deeper into that notch so that that square part will go by that center piece in order to fit down. At least that is what I had to do. |
Lo-Fi Version | Time is now: 4th May 2024 - 06:26 AM |
