Tangerine Stainless Pushrod tubes, Anybody running with these? |
Superhawk996 |
Aug 17 2019, 03:58 PM
914 Guru Group: Members Posts: 5,826 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Looking at the Tangerine Stainless Push Rod tubes.
Like the ideal of stainless and slightly improved clearance to exhaust, like the ring to help push/pull for install/removal. Also like the idea that stainless is a poor conductor of heat - maybe help prevent some heat transfer from exhaust pipes? Any improvement in leak resistance? Gotta admit the stock pushrod tubes worked well for me in past but of course I always had weeping even with Viton. Searches on this site and Google not turning up much information. Wondering if anyone is running these? A bit pricey so looking for some sort of rationalization that it's worth the trip. |
Mark Henry |
Aug 17 2019, 04:29 PM
Installed customer purchased a set on a stockish engine, I felt money could be better spent elsewhere.
IIRC there's a set that's extra long which would be good for strokers running big cylinder base spacers and cleared to fit big header stubs, in these cases I can see it being worthwhile. Biggest issue with stock tubes is they can rust out, not much of an issue with fair weather cars. BTW I repair dented tubes by pressing an old socket through them. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:38 PM |
