Canton 10 qt. oil tank level w/fron mounted cooler, What a safe number of quarts for 2.7 6cyl |
AnthonyM |
Aug 18 2019, 04:27 PM
Newbie Group: Members Posts: 38 Joined: 8-December 12 From: Hudson, OH Member No.: 15,243 Region Association: North East States |
Just purchased a non running 914-6 GT with a Canton front mounted oil tank and Mocal front mounted oil cooler (25 row .50L capacity). I know that 9 quarts is probably a safe capacity for a standard set up with a factory 914-6 oil tank, but how many quarts should I use for safe operation with this set up? No dip stick in oil tank. This will be a street car to begin with. The engine is a 2.7 with CIS.
GregAmy |
Aug 19 2019, 06:32 AM
Advanced Member Group: Members Posts: 2,308 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
You have a /6 right? Then you have a dry sump.
We probably have the same tank: https://www.summitracing.com/parts/ctr-23-110r As long as there's not ZERO oil in the tank, you have adequate supply for idling. Starting with 6 quarts should be perfectly safe, and then put it on a high idle and monitor the oil level until you can start to see the level. Then I'd knock off one quart next time. You don't want the resting level above that de-foaming plate because then you're bypassing the purpose of that plate. My level sits roughly one quart below the edge of the plate. If I remember, I'll take a photo of the dipstick tube that Chris fabbed. It's really easy if you have the welding skillz I don't, Chris def does...) |
Lo-Fi Version | Time is now: 26th May 2024 - 12:26 AM |
