Canton 10 qt. oil tank level w/fron mounted cooler, What a safe number of quarts for 2.7 6cyl |
AnthonyM |
Aug 18 2019, 04:27 PM
Newbie Group: Members Posts: 38 Joined: 8-December 12 From: Hudson, OH Member No.: 15,243 Region Association: North East States |
Just purchased a non running 914-6 GT with a Canton front mounted oil tank and Mocal front mounted oil cooler (25 row .50L capacity). I know that 9 quarts is probably a safe capacity for a standard set up with a factory 914-6 oil tank, but how many quarts should I use for safe operation with this set up? No dip stick in oil tank. This will be a street car to begin with. The engine is a 2.7 with CIS.
GregAmy |
Aug 19 2019, 04:24 PM
Advanced Member Group: Members Posts: 2,308 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Ah, yes. You remind Greg so he can go "ah yes, I said I'd remember to do that..." (IMG:style_emoticons/default/smile.gif)
1st shot shows how it's mounted. Now, were I highly motivated I'd swap the fuel cell to a Patrick cell in the stock location and then move the oil sump tank to the front. But the prior owner put the cell up there and I'm not highly motivated enough to change it (it's a historics racer, not much of a performance need). 2nd shot shows the bung that Chris welded into the tank so I could use the stock 914/4 dipstick. 3rd shot shows roughly how far down I run the tank on my /4; I ensure there's at least something on the dipstick when it's running. Last shot is as close as I could get to showing the de-foaming plate inside. You don't want the level at or above there, otherwise the oil cannot settle on it to allow the air bubbles to "de-aereate". For my /4 engine, adding 8 full quarts after an oil change works great. How much you need will depend on how your system is plumbed and how much "excess" there is in the /6 engine. Attached image(s) |
Lo-Fi Version | Time is now: 26th May 2024 - 02:17 AM |
