Ignition Switch Removal Help, Steering Column Assembly Disassembly |
Highland |
Aug 18 2019, 05:25 PM
Senior Member Group: Members Posts: 512 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
So I've read all the threads and can't figure out what I'm missing to pull the ignition switch out. The steering column is out of the car and I can't even get the ignition assmebly to budge from the backside (side of the connectors). This is the phase I'm at:
Also, do circlips on both ends need to be removed to remove the black housing. The allen bolt is already removed. |
914Sixer |
Aug 18 2019, 05:48 PM
914 Guru Group: Members Posts: 8,872 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Turn the key to on position and pull up. Nothing else has to be removed.
Highland |
Aug 18 2019, 06:01 PM
I tried that with no luck. This is the key that starts the car and unlocks the steering, but is it possible I have the wrong key? Does turning the key to the on position release something?
Superhawk996 |
Aug 18 2019, 06:38 PM
914 Guru Group: Members Posts: 5,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
You need the column lock pawl to release and retract into the lock housing are you sure that is happening?
Column might be free to spin but still hanging up enough to prevent it from coming out? |
steuspeed |
Aug 18 2019, 09:06 PM
Senior Member Group: Members Posts: 1,005 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Turn the key. Might need the steering lock to be off, so turn the wheel. The whole thing will slide out.
Chi-town |
Aug 18 2019, 10:56 PM
What year car?
If it's a 73+ There's a large Allen head bolt that comes up from underneath (have to remove the lower dash) Take it completely out, remove the steering wheel and the c-clip behind it. Slide the entire housing off the shaft. You'll be able to get the switch from the rear with a single screw |
Lo-Fi Version | Time is now: 2nd May 2024 - 05:04 AM |
