Ignition Switch Removal Help, Steering Column Assembly Disassembly |
Highland |
Aug 18 2019, 05:25 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
So I've read all the threads and can't figure out what I'm missing to pull the ignition switch out. The steering column is out of the car and I can't even get the ignition assmebly to budge from the backside (side of the connectors). This is the phase I'm at:
Also, do circlips on both ends need to be removed to remove the black housing. The allen bolt is already removed. |
914Sixer |
Aug 18 2019, 05:48 PM
Turn the key to on position and pull up. Nothing else has to be removed.
Lo-Fi Version | Time is now: 18th May 2024 - 07:49 PM |
