Center Caps for Fuchs, Pedrini and Mahle |
WPEngels |
Aug 19 2019, 02:59 PM
Newbie Group: Members Posts: 18 Joined: 20-November 13 From: Netherlands Member No.: 16,678 Region Association: None |
Hi all,
Long time ago, after finding a nice set of 2.0L Fuchs, I was looking for the center caps that belong to them. Expensive! There's sets on Ebay now, a used set with "dents, dings and scratches" for $339.95 + $66.20 postage, or a NOS set for $799.95 + $75.25 postage, with "some small production lines in the sides of the caps, above the lips. Additional polishing would help". So, I made center caps out of solid aluminum. After many evenings working the mill and lathe, I was very happy with the result. Until recently.... I had a cap CNC machined out of AISI 304 stainless steel! IMHO the result was absolutely stunning, even without polishing. Photos are showing the result before and after polishing, and comparison to my attempt in aluminum and an original but dented cap. Now I don't like the aluminum ones anymore (IMG:style_emoticons/default/sad.gif) . I've been borrowed the original to measure it's shape and dimensions. And changed the CAD model to be as accurate as possible. So I'm ready for the next step: have a complete set CNC machined, matching an original one as much as possible. But again, too expensive. Guess the 914 is called a poor man's Porsche for a reason. I got following quotation (subject to change), it's price per cap, not polished, without postage. For polishing, $7 needs to be added: 4 <=> $108, 20 <=> $46, 48 <=> $32, 80 <=> $26, 100 <=> $23. Do you think these prices are reasonable? I also wonder if others might be interested, that way helping get the cost per set down. So I can get myself a set for a nice price as well. And I don't want to make money on fellow 914 drivers so I'm perfectly okay with showing the actual quotation to people interested. And note, these caps will fit Fuchs, Pedrini and Mahle wheels, just push them in. There's clips that will hold the caps in place. Thanks and kind regards, Wilbert Engels |
dr914@autoatlanta.com |
Aug 19 2019, 03:15 PM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
mark at 914 rubber sells a nice 59 mm brushed cap and we sell a nice 59mm polished cap, I think that mark's are about 20 each and ours 29 each. No reason to make another although yours are very nice. Factory ones are about 90 each
WPEngels |
Aug 19 2019, 03:20 PM
mark at 914 rubber sells a nice 59 mm brushed cap and we sell a nice 59mm polished cap, I think that mark's are about 20 each and ours 29 each. No reason to make another although yours are very nice. Factory ones are about 90 each I know, and they look really nice, both yours and 914 Rubber's. But I think stainless steel has a different shine or colour than aluminum ones. That's why I tried making caps in stainless steel. |
Mikey914 |
Aug 19 2019, 03:32 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
mark at 914 rubber sells a nice 59 mm brushed cap and we sell a nice 59mm polished cap, I think that mark's are about 20 each and ours 29 each. No reason to make another although yours are very nice. Factory ones are about 90 each I know, and they look really nice, both yours and 914 Rubber's. But I think stainless steel has a different shine or colour than aluminum ones. That's why I tried making caps in stainless steel. You are correct Stainless will look great, but you will need to use a 316 alloy not a 304 / 305 (which is more machinable), as it will brown. Galvanic corrosion will be an issue with the lower grade. |
WPEngels |
Aug 19 2019, 10:16 PM
mark at 914 rubber sells a nice 59 mm brushed cap and we sell a nice 59mm polished cap, I think that mark's are about 20 each and ours 29 each. No reason to make another although yours are very nice. Factory ones are about 90 each I know, and they look really nice, both yours and 914 Rubber's. But I think stainless steel has a different shine or colour than aluminum ones. That's why I tried making caps in stainless steel. You are correct Stainless will look great, but you will need to use a 316 alloy not a 304 / 305 (which is more machinable), as it will brown. Galvanic corrosion will be an issue with the lower grade. That's a good remark, thanks. I'll check what the consequence of changing to AISI 316 would be. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:14 AM |
